I need a workng bios on this model Asus x512d , laptop suddendly not working check all voltages present, and theres is 1.8v on pin 3 7 8 of the bios chip anyone have a working dump please
Asus x512d
Tags: None
Re: Asus x512d
1v8 for a flash bios chip is normal these days. It is very possible that your flash device is truly designed to operate @ 1v8.
What are the full markings on the flash device ? With this detail -> search for the datasheet and review the voltage range for the Vcc parameter = power rail. Respectively, the I/O pins will also toggle at the same max voltage value. -
Re: Asus x512d
If there are no stickers post the silkscreened part number, such as X512DK RevComment
Re: Asus x512d
ASUS Vivobook 15 X512DKAttached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: Asus x512d
You didnt post your bios backup.If you want to add your DMI use Asus Block Transmit tool (WBT.exe windows version) https://www.badcaps.net/forum/showpo...43&postcount=5 ,or you can add it with a hex editor from your backup. If there is a win key its best to add the dmi from your backup .Comment
Re: Asus x512d
Tried it still there is no light 1.8v on pin 3 7 8 on the bios chip is present and there is 3.3v on keyboard switch , history of this laptop battery drain then suddenly not working,I have attached original file ec is IT8225EAttached FilesComment
Re: Asus x512d
battery drain is unlikely to be a bios problem.If there is no cmos battery then the main battery is used as cmos for the RTC .Comment
Re: Asus x512d
Already tried removing and plugging back in still no light when charger plugged inComment
Re: Asus x512d
Bios and EC extracted from the Asus site updateDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Re: Asus x512d
Thanks already done that but there is the problem cannot write the chip it says write false, maybe this kbc is faultyComment
Good Day! Need bios dump of Asus x512D mobo.X512DK
or clean me
Thanks in advance!
attached is my original Asus x512d bios dump
Attached FilesNever stop LEARNING because life never stops TEACHING!Comment
Last edited by Duranitron; 11-25-2024, 02:48 AM.Never stop LEARNING because life never stops TEACHING!Comment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by lrouw84Hi there,
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
by DynaxSCHi,
Usually on ASUS boards it worked...-
- Loading...
