BIOS Aspire A514-54G FH5AT LA-K092P.
  • huzo
    • Sep 2014
    • 218
    • CROATIA
    • electronics mostly,gaming, keyboadr and accordeon player
    #41
    Can someone repair mine? I have 0.17A ,after power on 0.9A and the again 0.17A, other dumps give me fan spin and 1A draw 4 times sequence then stop at 0.17A,and the powers up,draws 1A ,but no picture
    SN is NXA1JEX0052021F9913400 SNID: 20212942534 The board is : FH5AT LA-K092P Rev. 2.0 2021-10-18
      • 24142
      The bios is corrupt, make another backup. The serial number is for an A515-56G ,the bios type for that is FH4AT . Check the motherboard model number again , is it FH5AT or FH4AT
      • huzo
        • Sep 2014
        • 218
        • CROATIA
        #43
        This is the board,and it is 56G..unless someone already flashed the wrong dump before...
          SMDFlea commented
          Editing a comment
      • huzo
        • Sep 2014
        • 218
        • CROATIA
        #44
        Ispravljena verzija:
        Too late, I already flashed the chip, and it seems the chip was faulty because I couldn't erase it at first. Then it took only 10 seconds to erase, which seemed too short, so I tried erasing it again. After that, it locked up and I couldn't stop the program. I resoldered it to rule out any loose connections, but the result was the same. I also tried a different programmer with the same outcome. Then I took another chip and erased/flashed it without any problems. Unfortunately, I don't have a better backup copy.
      • huzo
        • Sep 2014
        • 218
        • CROATIA
        #45
        I have...
          • 24142
          I have...
          Make another backup and compare it to the bios you flashed, see if it looks corrupt. Check the bios with MEAnalyzer as well, it should have initialised the ME firmware. Try another bios chip , flash the EC , if that doesn`t make any difference then it will have some other problem.
          • huzo
            • Sep 2014
            • 218
            • CROATIA
            #47
            I can't make another backup because the chip is bad...i tried like all dumps from the forum here...
              • 24142
              I know, i want you to backup the current bios that you flashed to the chip and compare it with the file you flashed see if it looks corrupt. Check the current bios backup with MEAnalyzer as well, it should have initialised the ME firmware , if it`s still Configured then the bios chip isn`t being read/written to
              • huzo
                • Sep 2014
                • 218
                • CROATIA
                #49
                The issue with the original chip was that it was faulty...with it the laptop drew only 0.083A at power on and went back to 0.17A, then i tried to read it and got what i got,and then tried erasing it and it was giving me trouble,wouldn't erase ,and then next time it said erased after just 10 seconds, then third time it locked the neoprogrammer,it was recognized,and i did read from it and made a backup,but it was something wrong with the chip obviously since the dump is corrupted and it wouldn't erase...I got heaps of donor boards and i took the other 128Mbit chip from some donor board and it erased succesfully and programmed and now i have everything going ,but no picture, the board starts and draws around 2A now and it resets a few times (4 or 5) and the sixth time it stays off,then i press the power button,fan spins ,proc is getting warm,all voltages present,but shuts down to 0.17A and then starts at 2A again ,probably charging...So i think it's either the bios or ddead GPU,but not likely the GPU,
                • m1ch43lzm
                  • Mar 2019
                  • 2367
                  • Peru
                  #50
                  Try post 5 from here (A515-56G): https://www.badcaps.net/forum/troubl...43#post3169743
                  Flash chips in VSCC table:
                  EF4018 (Winbond W25Q128), use W25Q128JV
                  207018 (Unknown 00207018h), XM25QH128A
                  C84018 (GigaDevice GD25x128), use GD25Q128E
                  1C7018 (EON EN25QH128)
                  • huzo
                    • Sep 2014
                    • 218
                    • CROATIA
                    #51
                    Ok will try that dump from a banned guy ...
                    Why are chip types important?Aren't they all the same?
                      • 24142
                      The motherboard is FH5AT . Someone has replaced the base cover from a different laptop or the FH4AT motherboard has been swapped with the FH5AT
                      • huzo
                        • Sep 2014
                        • 218
                        • CROATIA
                        #53
                        Yeah could be,not gonna argue with that...
                        • m1ch43lzm
                          • Mar 2019
                          • 2367
                          • Peru
                          #54
                          It matters on Intel platforms, MXIC branded BIOS chip won't work in this laptop, only the specific ones in the list (Winbond, Gigadevice, XMC, EON)
                          The other dump from post 3 on the thread I linked looks like it's from a working laptop and has Initialized ME region (not clean), if it works it may take long time to boot and won't detect SSD, you need to clean ME region on that one first
                          It's the same board and BIOS for 14" and 15" models it seems
                          Checked the BIOS for the A515-55 (not G) and the BIOS is also the same (labeled FH4AT in BVDT), even if the board is labeled FH5AT... (The schematics are labeled FH7AT/FH5AT/FH4AT LA-K092P)
                          • huzo
                            • Sep 2014
                            • 218
                            • CROATIA
                            #55
                            It matters on Intel platforms, MXIC branded BIOS chip won't work in this laptop, only the specific ones in the list (Winbond, Gigadevice, XMC, EON) Ok , i used a winbond,,,
                            The other dump from post 3 on the thread I linked looks like it's from a working laptop and has Initialized ME region (not clean), if it works it may take long time to boot and won't detect SSD, you need to clean ME region on that one first, ok will try also...
                            Checked the BIOS for the A515-55 (not G) and the BIOS is also the same (labeled FH4AT in BVDT), even if the board is labeled FH5AT... (The schematics are labeled FH7AT/FH5AT/FH4AT LA-K092P)[/QUOTE]
                            • Olegst44
                              Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
                              by Olegst44
                              I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
                              Device Information:
                              - Model: Acer Aspire 3 A315-22G
                              - Motherboard: NB8607G02-MB (Compal LA-J761P)
                              - BIOS Chip: Winbond W25Q64 (8MB)
                              - Serial: NXHE7ER00X95002B784S00
                              Problem:
                              - BIOS is password protected (Supervisor Password)
                              - Boot from USB is disabled in BIOS
                              - After 3 wrong password attempts, system shows Unlock Key Hint
                              - I have RT809H programmer available
                              What I need:
                              1. Clean BIOS dump (password...
                              04-11-2026, 05:36 PM
                            • EbrahimSiami
                              Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                              by EbrahimSiami
                              I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                              **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                              **What I have tried so far:**
                              1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                              07-02-2025, 02:31 PM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • zarabota
                              Acer Aspire A717-71G - problem BIOS with keyboard
                              by zarabota
                              I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
                              However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
                              09-03-2025, 01:58 AM
                            • cr4zychriss
                              by cr4zychriss
                              • Rebrand: PC Specialist
                              11-14-2025, 04:04 PM
