Dell Latitude 5501 Bios password
  • drips
    • Sep 2020
    • belgium
    I'm new here, I received a Dell 5501 which has a locked bios.
    I tried unlocking it trough bios-pw.org, but seems like this doesn't work with the service tag suffix "8FC8".
    If i understand correctly this is the procedure?:
    1) Open up the laptop, remove battery and locate the BIOS Chip
    2) Use a ch341a programmer, and take a backup of the bios.
    3) Upload the bios backup here
    4) Receive "updated" here on the forum
    5) Download the new bios to the chip
    Is this correct? Any risks involved in this?
    Thanks!
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria πŸ‡§πŸ‡¬
    Re: Dell Latitude 5501 Bios password
    Thanks!
    1 to 5 - yes. In general, the procedure is described correctly.
    The only problem is the successful reading of the chip, and accordingly its writing with the unlocked dump - this programmer is notorious for its erratic performance.
    Being cheap in buying tools hides some unexpected surprises.
    https://www.badcaps.net/forum/showth...t=95856&page=4
    Become a Badcaps supporter
    Thanks to all supporters.​
    • hoaca388
      Badcaps
      • Jan 2022
      • 12419
      Thanks!
      Correct, remove all battery ( main and CMOS battery ).
      ​https://www.badcaps.net/donate
      • drips
        • Sep 2020
        • belgium
        Thanks for the feedback @Vesko356 & @hoaca388.
        I will order an TL866II programmer, is it necessary to desolder the chip or can i use the clamp adapter & program it "in circuit"?
        I prefer to not desolder..
        Thank you.
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria πŸ‡§πŸ‡¬
          Thank you.
          In general, for the best result chip must be unsoldered from the board, but it can also be done in circuit - the result depends on the quality of the clip used for this purpose.
          • shafeequ
            • Jul 2022
            • indea
            bios passsword
            • Derach
              • Jun 2017
              • 17
              • burkina faso
              hello i have dell 5501 locked from administrator 8fc8
              i have backed locked bios ,i need help to unlock
                • 22103
                Type the laptop service tag
                read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                • Derach
                  • Jun 2017
                  • 17
                  • burkina faso
                  sorry
                  service tag is D4L1X33
                  • Markus1741
                    • Sep 2020
                    • 965
                    • N/A
                    sorry
                    Hello try ....
                    • Derach
                      • Jun 2017
                      • 17
                      • burkina faso
                      Hello try ....
                      perfect work for me thanks everything
                      • Godfather79
                        Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                        by Godfather79
                        Hello everyone in the community
                        Dear Sir,
                        I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                        Problem details:
                        * Model: Dell Latitude 5520.
                        * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                        * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                        * Service Tag: (Enter your actual Service Tag from the laptop here)
                        * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                        11-08-2025, 10:04 AM
                      • gizaha
                        by gizaha
                        02-13-2024, 07:18 AM
                      • jhanra
                        by jhanra
                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                        11-02-2024, 04:19 AM
                      • anlsmith
                        Dell Latitude 5430 Bios Password
                        by anlsmith
                        I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                        08-31-2024, 08:46 PM
                      • YOUCEF4787
                        Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                        by YOUCEF4787
                        I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                        Initial Problem:
                        The laptop was completely dead, no signs of life, no power LED.
                        Action Taken:
                        I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                        Current Situation & The Main Issue:
                        The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                        09-21-2025, 12:19 PM
