asus n53jq
  • dikmen
    • Apr 2015
    • 49
    • TURKIYE
    asus n53jq
    hi
    asus n53jq bios dump please
  • cacla
    • Apr 2015
    • 442
    Re: asus n53j weird problem.
    Try this one
    • dikmen
      • Apr 2015
      • 49
      • TURKIYE
      thanks cacla
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Anchar777
        ASUS P1412CE need BIOS DUMP
        by Anchar777
        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
        06-26-2025, 03:39 AM
