hp probook 450 g8 bios
  • farouk_1994
    • Mar 2021
    • 392
    • algeria
    Hello i had problem hp probook 450 g8 was locked it has 2 chips 32mb one of theme was lost unfortunately without save the original main dump , the SN: 5CD130G3LX.
    the other dump EC :GD25Q256C@SOP16
  • hoaca388
    Badcaps
    • Jan 2022
    • 11727
    Re: hp probook 450 g8 bios lost
    Unfortunately the unlocking is done on the EC chip but with the condition that the original bios is kept. In the forum, there is a case of losing the original bios and everything is coming to a standstill.
    • farouk_1994
      • Mar 2021
      • 392
      • algeria
      i know this in my case the laptop has 2 bios chip 32mb first one is EC and the
      other is main so i lost the main chip without read or save the dump
      and you are correct the unlocking is done on the EC chip
      if you have any idea to resolve this or make a new dump help me please sir
      • DanielDacko
        • Mar 2015
        • 325
        • Macedonia
        Post the mainboard number.
        I don't provide help for people using CH341A and a clip.
        • farouk_1994
          • Mar 2021
          • 392
          • algeria
          i solved the problem finaly thank you sir
          • keithlutes
            • Feb 2021
            • 7
            • canada
            How did you solve your issue? I had a bios locked 450 G8, i removed chip to read and got someone else to remove password. I flashed the .bin that they gave me to the chip and was in manufacturing mode. Then removed the chip again and was told to flash back the original .bin (which i still have). I then tried updating the bios from inside the bios via ethernet. It had 5 updates to do. On the 5th update, it said finailizing bios update, then retarted into a constant bootloop. Since that, I can no longer get it to boot anymore and it flashes 7 white on num lock, indicating bios. Any help would be appreciated.
            • keithlutes
              • Feb 2021
              • 7
              • canada
              probook 450 g8 - not sure if programming is correct
              I have a bios locked 450 G8 (was locked actually), i removed chip to read .bin and got someone else to remove password. I flashed the .bin that they gave me to the chip and was in manufacturing mode. Then removed the chip again and was told to flash back the original .bin (which i still have). I then tried updating the bios from inside the bios via ethernet. It had 5 updates to do. On the 5th update, it said finailizing bios update, then retarted into a constant bootloop. Since that, I can no longer get it to boot anymore and it flashes 7 white on num lock, indicating bios. Any help would be appreciated.
              the 3 attached are
              1.probook 450 g8 is the original locked bin
              2.unlocked-probook 450 g8 is the .bin that someone unlocked for me from the original
              3.newprobook450g8 is the .bin i was told to flash after i explained the bootloop situation.
              the guy who unlocked for me doesnt speak the best english and i feel some sort of miscommunication mightve happend.
              • anhbanxoi
                • Sep 2021
                • 172
                • VN
                Try flash the original bios
                • keithlutes
                  • Feb 2021
                  • 7
                  • canada
                  I have tried flashing back the original and same thing. Ill try again though.
                  • Zarnescu123
                    • Jan 2020
                    • 3
                    • Romania
                    HELLO, CAN YOU PLEASE HELP ME
                    hp probook 450 g8 lost BiOS
                    MB: DAX8QAMB8D0 REV D
                    SN:5CD125VMQ7
                    i have just original ec
                    • skazide
                      • Jul 2015
                      • 142
                      • morocco
                      SN:5CD125VMQ7
                      try
                      • Zarnescu123
                        • Jan 2020
                        • 3
                        • Romania
                        Originally posted by skazide
                        try
                        led blinking, no power no image...
                        • skazide
                          • Jul 2015
                          • 142
                          • morocco
                          other one
                          • Zarnescu123
                            • Jan 2020
                            • 3
                            • Romania
                            other one
                            Blinking capslook 7 times
                            • rex98
                              • Feb 2023
                              • 1277
                              • Mandaue CEBU, Philippines
                              try. test that two and give feedback.
                              • Blallowinformatic
                                • Mar 2020
                                • 27
                                • México
                                Originally posted by Blallowinformatic
                                Hello good day, need help with bios password unlock
                                HP ProBook 440 G8
                                Board: DAX8QAMB8D0 REV D
                                Chip: MX25L256736 (3.3V)
                                Prod ID 2F3X9LT#ABM
                                SN#5CD118M8DJ
                                Warranty: ly ly Oy
                                Build ID: 20WWR3CT601#SABM#DABM
                                Feature Byte:
                                3X476J6S6b7B7J7M7Q7W7m7saBapaqauawbUbhcAdUdpdqfPguk8mEn7nV.Ge
                                Thanks in advance for any help or guidance provided. ​
                                Oh no wrong model
                                • Vesko356
                                  Vesko356 commented
                                  Editing a comment
                                  Your off topic request is removed, use the forum search to find related threads where you can post.
                              • evil910
                                • Jul 2021
                                • 3
                                • peru
                                Good afternoon, can someone help me with the HP ProBook 450 G8, which has a corrupt bios. I thank you in advance for any help.
                                ProdID 63T19LS#ABM
                                SN #5CD21743L9​
                                • altapro
                                  • May 2025
                                  • Tunisie
                                  Thank you for posting the solution , because much membre has the same problem
                                  • hani55
                                    • 101
                                    • morocco
                                    HELP ME TO REPAIR BIOS EC DUMP NO POWER BLINKING
                                    HP PROBOOK 450 G8
                                    main board DAX8QMB28A0 REV A
                                    SN 5CD1479YDS
                                      SMDFlea commented
                                      Editing a comment
                                      post moved from 440 G8 topic...........
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11727
                                    HP PROBOOK 450 G8
                                    SN 5CD1479YDS
                                    HP ProBook 450 G8 Notebook PC IDS Base Model_T70
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • studdy05
                                      Bricked HP Probook 450 G7 Bios questions
                                      by studdy05
                                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                      Ive got...
                                      07-08-2025, 09:24 PM
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
                                    • solomost
                                      need bios dump for HP ProBook 640 G2
                                      by solomost
                                      HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                                      prblm: black screen caps lock blinking 5 times then fan spening
                                      CT: PFKCT00WB69310 REV : 1.20
                                      motherboard : HSB J Mv-6 94v-0 E89382
                                      03-21-2025, 06:22 AM
                                    • MDSI
                                      HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                      by MDSI
                                      I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                      Details:
                                      Model : HP OMEN 17-an012nf
                                      Motherboard Part Number : DAG3BAMBAF0 REV : F
                                      Serial Number (S/N) : 5CD7280D51
                                      BIOS chip : Winbond W25Q64VSIQ
                                      Programmer : EZP2023+
                                      Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                      I already...
                                      07-28-2025, 07:11 AM
