Bios request for Satellite P50-C-147 PSPTSE
  • Greg81
    • Jul 2020
    • 9
    I have motherboard DABLQMB16B0 Rev. B from Toshiba Satellite P50-C-147 with no init. I could not find any free download so far. According to a paysites title BIOS for following Models should fit also: PSPTNE, PSPTPE.
    I tried the PSPT2E one I found on this site, but it did no work.
    Does anybody have a working dump or even a copy of offical update?
    Any help is welcome!
    Thanks in advance!
    • 20695
    Re: Bios request for Satellite P50-C-147 PSPTSE
    Do you have the original bios backup,if so post it.
    • Greg81
      • Jul 2020
      • 9
      This is the original dump. I tried to clean ME with ME/TXE Injector tool before without success...
        • 20695
        Here`s a virgin bios extracted from update 5.30,with your DMI.
        • Greg81
          • Jul 2020
          • 9
          Thank you ver much! But unfortunately the behaviour did not change. It stucks at 600mA consumption and no init.
          All main power rails have voltage. I removed the audio codecs as it looked to me somewhat too warm. GPU and CPU power blocks are at 55° C. NVIDIA dGPU power rail has impendace of 10 ohm. Maybe its too low and the GPU is faulty...
          Or do you have any further ideas regarding the BIOS?
            • 20695
            The bios is fine,you have some other issue.If you want any more help start a new thread in the main laptop forum.
            • Greg81
              • Jul 2020
              • 9
              OK, I'll check what else could go wrong. Thanks so far.
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • David Gee
                Bios Request HP 17-CN0023DX
                by David Gee
                I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
                I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides...
                05-03-2025, 09:58 AM
