Acer E1-731 Bios Unlock
  • Kashi1712
    • Jan 2017
    • 73
    • Belgium
    I'm trying to find a way to extract the bios password for an Acer E1-731. I've extracted the bios + EC but i have a lack of knowledge on how to find the bios password in the HEX editor.
    This laptop is unused since 3 years and I did forget to remove the password at that time (i have another one where I removed the password when i decided to store them)
    Find enclosed BIOS + EC.
    Board number :69N099M13A01 - 12667677 - NBRYR11001346029B47200
    Any hint or help will be much appreciated! :-)
  • hoaca388
    Badcaps
    • Jan 2022
    • 11687
    Re: Acer E1-731 Bios Unlock
    For 10 digits, see here: https://www.badcaps.net/forum/showthread.php?t=84084
    • Kashi1712
      • Jan 2017
      • 73
      • Belgium
      Hey,
      Thanks for the answer, I did forget to tell, i've seen this but i'm not getting any 10-digit, just that the system will halt and that's it.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11687
        https://www.manualslib.com/manual/44...page=65#manual
        Maybe it usefull for E1-731 model
        • Kashi1712
          • Jan 2017
          • 73
          • Belgium
          Originally posted by hoaca388
          Thanks, did check, i haven't those pins next to one of those ram slots.
          I did found the service manual of the v3-771 (that looks similar to my model) and found the corresponding pins but unfortunately, it doesn't work either:
          ""Chapter 5
          Steps for Clearing BIOS Password Check
          If users set BIOS Passwords (Supervisor Password and/or User Password) for a security
          reason, BIOS will ask the password during systems POST or when system enters the BIOS
          Setup menu. If it is necessary to bypass the password check, short the HW Gap to clear the
          password by performing the following steps:
          1. Remove power from the system.
          2. Remove HDD, AC and Battery.
          3. Disconnect the RTC Battery (Figure 5-3).
          4. Locate the RTCRST# jumper.
          5. Use an electric conductivity tool to short the two points of the RTCRST# jumper.
          6. Plug in AC, keeping the RTCRST# jumper shorted.
          7. Press Power Button until BIOS POST is finished, then remove the conductivity tool from
          the RTCRST# jumper.
          8. Restart the system. Press F2 to enter BIOS Setup menu.
          9. If there is no Password request, BIOS Password is cleared.
          10. If a password is requested, repeat Steps 1 through 9."
          I did exactly what has been documented, but with no sucess. There is two RTCRST jumpers (JRST2001 & JRST2002), shorted both and tried several things but no luck at all.
            • 20781
            Originally posted by Kashi1712
            Hey,
            This might be it
            • Kashi1712
              • Jan 2017
              • 73
              • Belgium
              Originally posted by SMDFlea
              This might be it
              Will give it a try, Thanks !
              • Kashi1712
                • Jan 2017
                • 73
                • Belgium
                Thanks mate ! That was it :-)
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11687
                  Interesting, it is a clear text
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • peterhui
                    BIOS PASSWORD UNLOCK NEEDED (ACER TRAVELMATE P645-S)
                    by peterhui
                    Model : TMP645-S-504E
                    S/N: NXVAFEG0085490148C3400
                    like to unlock the bios password:
                    tried biosbugs keygen not working.
                    tried bios-pw unlock key still no luck.
                    Here is the two bios file : (Bios + EC)
                    Will definitely summit donation after that issue solve.
                    Thanks for your help and support
                    I really appreciated....
                    08-12-2024, 09:40 AM
                  • marc_ytos
                    bios password unlock acer AL14-31P
                    by marc_ytos
                    Greetings, please, if someone could help me unlock this Acer bios, I already tried RCUnlocker on my own but I was unsuccessful. The computer model is Acer Aspire lite 14 n23g1 AL14-31P-C0S2. The serial number is NXKS8AL00234902E3F4500. The motherboard is esm2309167. Thank you very much. beforehand...
                    07-11-2024, 06:39 PM
                  • Nopslide
                    by Nopslide
                    04-01-2024, 04:27 PM
                  • BlackVisor
                    How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                    by BlackVisor
                    RedmiBook Pro 1542022 6800H
                    SKU: TM2113-39463
                    Model Number: RMA2204-AB
                    CMIIT ID: 2022AP1835
                    SN: 39463/22WD01355
                    BIOS version: RMARB5B0P1010 20230628
                    1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                    2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                    3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                    01-14-2024, 06:35 AM
