looking for bios bin asus x415ma r.30
  • peste
    • Dec 2016
    • 12729
    • ROMANIA
    Originally posted by soupermen905
    Please I need bios for Asus x415MA-EB494.On mb sticker i have this data: ,MA42NBLP000T3PMB,X415MA,60NB0TG0-MB2013,301,
    board model : X415MA
    SN: MBN0LP00J136466
    CN: H9KE
    post the contents of the bios chip even if it is corrupted..
    • soupermen905
      • Aug 2015
      • 4
      • romania
      SN: MBN0LP00J136466
      CN: H9KE
      Contents of the bios chip :
      • danito
        • Jun 2016
        • 899
        • Romania
        try
        • soupermen905
          • Aug 2015
          • 4
          • romania
          Originally posted by danito
          try
          Thanks, but no change.Doesnt boot.
          • peste
            • Dec 2016
            • 12729
            • ROMANIA
            try post #12...
            https://www.badcaps.net/forum/troubl...se#post3508961
            • soupermen905
              • Aug 2015
              • 4
              • romania
              #26
              Originally posted by peste
              The issue with this laptop was a defective keyboard that prevented the BIOS from booting.
              Thank you for help!
              • lovejo
                • Oct 2023
                • 5
                • South Africa
                #27
                Asus X415MA bios working 100
                • peste
                  peste commented
                  Editing a comment
                  post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • lrouw84
                by lrouw84
                Hi there,
                01-28-2023, 01:31 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • chudofermer
                Asus Ally rc71l bios
                by chudofermer
                Hello!
                Received Asus Ally rc71l with the wrong bios.
                Have the original package and all serial numbers.
                Can anyone help me understand what is wrong?
                Condition:
                Received with an original box with all serial numbers
                Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                Got the flash dump, nothing found on DMI section
                No Windows key, just key ID on the box
                What is done:
                1. Flash the latest bios version with serial numbers...
                03-05-2025, 05:42 AM
