Dell password for Hynix SC210
+ More Options
Posts
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    I've had no success with a couple of Dell password generators, both originating from HPGL, Russia
    Trying the right 11 characters of SC210's serial number, and also the code given by Dell's lock message
    Also no success with BIOS_PW.ORG, using first 7 characters of Dell's lock message
    FWIW, BIOS_PW generates same codes when I input same as for HPGL
    Could someone please supply a password, or advise what I'm doing wrong above
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    Re: Dell password for Hynix SC210
    1l38lch8
    7l31hgft
    hCRBdj44et6NAibG
    s90b12lt
    ytwDIoKDLh87bXeG
    t3OOq2ZP7J9Y2Ii0
    rKbm2CtV52CcHSVB
    try some of these ones must work.better start from bottom to top;
    • anhbanxoi
      • Sep 2021
      • 178
      • VN
      Originally posted by bachir2004
      1l38lch8
      7l31hgft
      hCRBdj44et6NAibG
      s90b12lt
      ytwDIoKDLh87bXeG
      t3OOq2ZP7J9Y2Ii0
      rKbm2CtV52CcHSVB
      Pls help me generate some passwords for this code TNBRHCO4311-2A7B/TNBRHC04311-2A7B
      • hoaca388
        Badcaps
        • Jan 2022
        • 12135
        Have you tried entering the password using an external keyboard, US layout, USB 2.0 interface?
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          1l38lch8
          7l31hgft
          hCRBdj44et6NAibG
          s90b12lt
          ytwDIoKDLh87bXeG
          t3OOq2ZP7J9Y2Ii0
          rKbm2CtV52CcHSVB
          @hoaca388 I've now tried it, after reading your suggestion
          @bachir2004 Thank you for the effort
          Regretfully none of them work, trying both notebook keyboard and external keyboard
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            Mostly Ssd password accept when ssd lock same bios.If this Ssd lock same model then can unlock.
            If ssd lock other laptop and you want try dell other model
            i dont think its work.
            • anhbanxoi
              • Sep 2021
              • 178
              • VN
              Do you have any idea on how to erase those drive? I heard that this device can erase password protected drive but not sure if it's worth to try.
              StarTech USB 3.0 Hard Drive Eraser Dock for 2.5" & 3.5" SATA SSD HDD + 4Kn Drive - LCD/ RS232 - Secure Erase HDD Wiper Docking Station (SDOCK1EU3P2)
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Thank you to everyone who participated
                I am making progress
                Now have generated a password using https://beta.bios-pw.org/ (thanks SMDFlea) which is accepted with Ctrl&Enter from notebook keyboard
                But even though I see "Secure Erase in Progress", the Lock message returns when it reboots
                Noting imramromi's advice, tomorrow I'll put the SSD back in its original E7250, try again, and report back
                • bachir2004
                  • Feb 2015
                  • 439
                  • maroc
                  tomorrow I'll put the SSD back in its original E7250, try again, and report back[/QUOTE]
                  to unlock the ssd it must be in the original machine where the password has been created.
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    I did restore SC210 into original E7250
                    A bit disconcerting that suffix of lock message had changed from 2A7B to 1F66
                    Anyway I generated another password using https://beta.bios-pw.org/
                    This too was accepted with Ctrl&Enter from notebook keyboard, but unlike when SSD was in E6330, "Secure Erase in Progress" took two or three minutes
                    And when E7250 was rebooted, there was no error message and Dell BIOS Security showed Primary disk: No password set
                    Thanks again to everyone who participated
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
                    • master3112
                      by master3112
                      07-29-2025, 01:55 PM
                    • F R 2568
                      Dell Latitude 5420 does not start (no post) need help to find the reason why
                      by F R 2568
                      Hello all,
                      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                      If the laptop is only connected to the AC adapter (battery removed):
                      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                      The power/battery...
                      01-08-2025, 05:45 AM
                    • diamon
                      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                      by diamon
                      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                      Pictures of these boards:
                      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                      Dell...
                      02-28-2024, 12:51 PM
