need help dell Inspiron 3501 gen 11 LA-K034P
  • madushanka 1234
    • Apr 2019
    • 57
    • sri lanka
    #201
    Originally posted by qayyum786
    Try
    tried today ...but nvme not detected .. solution??
    • madushanka 1234
      • Apr 2019
      • 57
      • sri lanka
      #202
      Try
      brother now nvme is detecte...but sound not working...sloution>>??
      • LBTT1121
        • Nov 2024
        • 559
        • Việt Nam
        #203
        Originally posted by SYSLAN
        Can someone help me?
        ST: 5Q4NNJ3
        No sound, no USB.​
        try and feedback
        • SYSLAN
          • Sep 2019
          • 4
          • ecuador
          #204
          Originally posted by LBTT1121
          try and feedback
          It won't turn on. When I press the power button i get an amber light on the charger led and nothing else.
          • umesh
            • May 2018
            • 13
            • sri lanka
            #205
            I don't have the original backup.The attached file is not the original backup, The following two files have been written so far The service tag has changed and also manufacturing mode active. please help me. thank you!
            DELL inspiron 3501
            ST: 99JN6C3
            • hoaca388
              Badcaps
              • Jan 2022
              • 11809
              #206
              DELL inspiron 3501
              ST: 99JN6C3
              Inspiron 3501​
              • umesh
                • May 2018
                • 13
                • sri lanka
                #207
                Originally posted by hoaca388
                Inspiron 3501​
                Thank you!, with your help I was able to solve both my problems.
                Can I re-enter my previous Windows product key at this time? But I don't have it.
                • madushanka 1234
                  • Apr 2019
                  • 57
                  • sri lanka
                  #208
                  Flash from post #196
                  tried laptp working but sound not detected?? anyone help?
                  • EdwinTulcanaz
                    • Jan 2021
                    • 10
                    • Ecuador
                    #209
                    Hi, I have problems with Dell Inspiron 3501 without audio, could someone help me fix it please
                    11th gen i5
                    LA-K034P motherboard rev 1.0 (A00)
                    ST: 2N3XMJ3
                    I attach original files
                    Attached files​
                    • umesh
                      • May 2018
                      • 13
                      • sri lanka
                      #210
                      I had the same problem. After installing the OS and updating the drivers, it worked fine.
                      • madushanka 1234
                        • Apr 2019
                        • 57
                        • sri lanka
                        #211
                        already tried but not done.....
                        • umesh
                          • May 2018
                          • 13
                          • sri lanka
                          #212
                          Were you able to go into the Bios setup and edit the service tag and model number? If you do that too, there must be a hardware problem (sound ic).
                          • Bios Cracker
                            • Oct 2024
                            • 315
                            • India
                            #213
                            Originally posted by laptop24hvl
                            TPM Device not found error, PLEASE HELP ME
                            SERVICE TAG : 8CDRGJ3
                            Pls confirm....file is extracted correctly.
                            • madushanka 1234
                              • Apr 2019
                              • 57
                              • sri lanka
                              #214
                              sound ic is working..i previously tried some bins sound worked...
                              already lasttime tried bios with uploded different serial no....no need to enter
                              • umesh
                                • May 2018
                                • 13
                                • sri lanka
                                #215
                                Is the device out of manufacturing mode?
                                • madushanka 1234
                                  • Apr 2019
                                  • 57
                                  • sri lanka
                                  #216
                                  YES....FAN IS NORMAL...ONLY SOUND ISSUE
                                  • umesh
                                    • May 2018
                                    • 13
                                    • sri lanka
                                    #217
                                    flash both IC, go to bios setup, write service tag, save then choose one of the three models (3501).
                                    • SYSLAN
                                      • Sep 2019
                                      • 4
                                      • ecuador
                                      #218
                                      Following the instructions, still no audio. I tried also with a new OS as recommended by another user, nothing.
                                      2 things to consider for future reference:
                                      1. Windows won't detect any audio device as installed, like if there wasn't a Cirrus or Realtek in the mobo, it doesn't exist, no driver to install if there is no device to install the driver to.
                                      2. I noted that when I configured it, I had no audio option in BIOS, but after a BIOS update it appeared. Before and after the update there was no audio.
                                      Sadly I think that I'll give up since the client is a little anxious over their laptop.
                                      Thanks for the help, I really appreciate it!
                                      • rasta24
                                        • Feb 2022
                                        • 25
                                        • México
                                        #219
                                        please help TPM error and no audio
                                        Dell inspiron 3501
                                        ST:H359HJ3
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11809
                                          #220
                                          Dell inspiron 3501
                                          ST:H359HJ3
                                          Inspiron 3501
                                          Service Tag: H359HJ3​
                                            DELL Inspiron 3501 Notebook 3000 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3501 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3501 boardview and 3501 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3501...
                                            09-07-2024, 02:50 AM
                                            09-07-2024, 02:20 AM
                                            09-07-2024, 02:00 AM
