Asus F756UX X756U BIOS
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • Anchar777
    ASUS P1412CE need BIOS DUMP
    by Anchar777
    Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
    06-26-2025, 03:39 AM
