I need BIOS HP Elitebook 745 G5
  • tujuhkalitujuh
    • Oct 2013
    • 27
    • Indonesia
    Master pleas help me, I need the main and the EC dump, the main IC Bios is burned and cant dump it.
    the SN is: 5CG9152HXM
    Thank you very much
    • rex98
      • Feb 2023
      • 1293
      • Mandaue CEBU, Philippines
      Thank you very much
      read my post #14 https://www.badcaps.net/forum/troubl...29#post1866229
      • amirheidari681
        • Oct 2021
        • 43
        • iran
        HI. I need complete bios of this laptop
        model : hp elitebook 745 g5
        sn: 5cg917167h
        It is 16m+16m+2m bios
        the power led just blinking
        thanks​
        • Mudau
          • Sep 2020
          • 15
          • South Africa
          hi guys good evening
          Can anyone assist me with part id, u4501.
          EliteBook 745 g5.
          6050A2945701
            SMDFlea commented
            Editing a comment
            Off topic.The bios requests section is for bios requests only.
        • Mudau
          • Sep 2020
          • 15
          • South Africa
          I can't find option, to create a post in my profile.
          I don't knw if my profiile have a problem.
          • Czompi
            • Jun 2018
            • 10
            • Hungary
            #26
            I've got an HP EliteBook 745 G5 with the issue, that it is turning on, but does not display any image.
            I've dumped both BIOS files and attached them.
            Model: HP EliteBook 745 G5
            S/N: 5CG83279R4
            Mobo: TRYPTICO 6050A2945701-MB-A01 (A1)
            CPU: AMD Ryzen 5 2500U
            Regards,
            Czompi​
            • qayyum786
              • Aug 2018
              • 1959
              • INDIA
              #27
              S/N: 5CG83279R4
              Regards,
              Czompi​
              flash bottom one only
              • Czompi
                • Jun 2018
                • 10
                • Hungary
                #28
                qayyum786 thank you for your help. Sorry for the late reply, I just noticed yesterday, that you replied a few hours after I posted here.
                Today I flashed said BIOS chip, now the charging led is solid white and the orange led flashes 5 times. After and during those 5 orange flashes, the white led stays on.
                The power button flashes for a brief second when I plug the board gets power and after it nothing happens.
                This occurs even from battery power.
                • rex98
                  • Feb 2023
                  • 1293
                  #29
                  use this
                  • Czompi
                    • Jun 2018
                    • 10
                    • Hungary
                    #30
                    Thank you guys! Sadly it didn't work, still does the 5 flashes and white charging led on issue. I've reflashed the original firmware and it does the same, so probably something went wrong when I removed or soldered the BIOS chips.
                    I'll report after I tried a few more tricks, but still, thank you guys for the help.
                    • Mudau
                      • Sep 2020
                      • 15
                      • South Africa
                      #31
                      Check if you did not, shift any resistors when you take out the bios chip
                      • Czompi
                        • Jun 2018
                        • 10
                        • Hungary
                        #32
                        It turns out I did that and somehow in that process the resistor was rotated 90° and an another dissapeared. Now I've discovered that it was a 0Ohm one and found a replacement for the missing one and after I soldered them back the correct way it is now back to the original state. Thank you for suggesting it. These components are so small, that I've not noticed it 'till you mentioned that it might be the cause.
                        I've tried all two BIOS files above (and my original as well) and it is back to fans ramping up to full speed and no image with all mentioned (main) BIOS files.
                        The sympthom is the following:
                        When I plug in the laptop, it flashes the charging led orange while it is white, then it starts the laptop.
                        The charging white led turns off and the orange charging led stays on (no battery is connected). The power button now lights up white and the laptop turns on.
                        The fan is off in the beginning, but then it starts to ramp up as the CPU starts to heat up and the fan reaches full speed in about a minute. Few more minutes go by and still no image.
                        This was the original behavior.
                        I've also noticed a 3rd BIOS chip that is also a Winbond one, but that is only a 16Mbit chip (W25Q16JV). Can it be related to the issue mentioned above?​
                        • mily.gawel
                          • Aug 2018
                          • 42
                          • Polska
                          #33
                          Can someone unlock me this bios ? HP 745 G5 S/N 5CG933507L
                          • danito
                            • Jun 2016
                            • 1108
                            #34
                            try
                            • pitkatata
                              • Jan 2014
                              #35
                              hello, can anyone help me with one HP 745 G5
                              two bios chip are flashed with some wrong dumps and after that and now the laptop is death, no respons from any buttons and from power supply.
                              can anyone help me with virgin worked bios files?
                              Model: Elitebook 745 G5
                              SN#: 5CG8428KJH
                              Regulatory Model: HSN-I17C-4
                              ProdID 5KG94UC#ABB
                              Thank you in advance!
                              • pitkatata
                                • Jan 2014
                                #36
                                SN#: 5CG8428KJH
                                ProdID 5KG94UC#ABB
                                here is the dumps from my chips, i`m not sure the u366 is correct readed. Now laptop after write the origin files back turn on only fan with max power and orange WiFi led continous light.
                                Can anybody help me with correct Bios files for this machine please
                                • Mudau
                                  • Sep 2020
                                  • 15
                                  • South Africa
                                  #37
                                  Please check if you didn't move any resistors when soldering the bios chips
                                  • piszpunta
                                    • Jan 2019
                                    • 255
                                    • poland
                                    #38
                                    try this
                                    • pitkatata
                                      • Jan 2014
                                      #39
                                      Originally posted by piszpunta
                                      try this
                                      not working, caps and num lock blinking 5 times slowly with this dumps, WiFi orange led stay on and the fan come up to max speed a few seconds after power ON, and the power button led work.
                                      • pitkatata
                                        • Jan 2014
                                        #40
                                        can anybody help with this issue?
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
