Dell Latitude 5520 Bios Password unlock
  • Thoa
    • Jun 2025
    • 28
    Originally posted by b4rdock
    here is file unlocked
    Thx b4rdock for your reply. But you did not read I can't see! ... my 5520 does not even power on and my bios had no passwort set. But when i compare the size of my bios-file with others in here, i think much data has been deleted by the pending firmware-update and powerloss.
    I have an Dell Latitude 5520
    Service-Tag: 5176QG3
    Mainboard: Southpeak 15
    I do not know where i can get more specific infos on motherboard.
    Now I ve read it again and the size of the file is just like the avarage.
    And once more and the files are equal! Now my question: is anybody in here who can tell me if it is corrut or not?
    • Thoa
      • Jun 2025
      • 28
      opened the bin with UEFI TOOL and it looks pretty fine to me but the machine does not power on
      Dell Latitude 5520
      • hoaca388
        Badcaps
        • Jan 2022
        • 11902
        #683
        Dell Latitude 5520
        Latitude 5520
        Service Tag : 5176QG3
        • Thoa
          • Jun 2025
          • 28
          Originally posted by hoaca388
          Latitude 5520
          Do I have to plug off the CMOS Battery when flashing the chip or does it not matter?
          • hoaca388
            Badcaps
            • Jan 2022
            • 11902
            #685
            Normally the bios chip is powered from pin 8 of the programmer (I remember pin 8), but if there is a voltage drop, a cmos battery is needed.
            • Thoa
              • Jun 2025
              • 28
              Latitude 5520
              Thx hoaca38
              NeoProgrammer Reported succsess... Unfortunatelly it does still not power on. i am going to order a new cmos battery, cause i´ve cut the cable to bridge it for a second.
              Normaly it only starts programming when a notebookbattery is recocnized AND the power cord is connected. But as i mentioned in an early post it has shut off immediatelly.
              Thats why I think, something else is broken when i´ve pulled the powercord.
              I am going to read the eeprom and compare to your file as soon as the battery arrives, just to be sure.
              • rasta101
                • Mar 2025
                • Florida
                #687
                Hello everyone, after purchasing a Dell latitude 5520 MDM lock, what can you get?
                • Thoa
                  • Jun 2025
                  • 28
                  Latitude 5520
                  i verifyed, the data on the ic are exact what you posted. I am giong to try an older one of the post on 06-17-2024, 02-54 AM.
                  EDIT:
                  Does not work either.... for me, the notebook is dead.
                  • Thoa
                    • Jun 2025
                    • 28
                    i think pin 4 and 5 are voltage and gnd. and sorry for being offtopic
                    • FireFox7881
                      • Feb 2023
                      • 6
                      • Poland
                      #690
                      Hello dear friends
                      Please help me remove Dell Latitude 5520 bios password
                      Latitude 5520
                      Kod Service Tag: 34PT4B3
                      I am sending a bios dump
                      Thank you very much!
                        • 21204
                        Originally posted by FireFox7881
                        Hello dear friends
                        Latitude 5520
                        https://www.badcaps.net/forum/troubl...23#post1622423
                        • FireFox7881
                          • Feb 2023
                          • 6
                          • Poland
                          #692
                          The laptop has had several owners and I have no information about its history over the past few years. A friend brought the laptop to me asking for help. Of course, I am categorically against illegal actions. As far as I know, he bought this laptop used and also does not know its history.
                            • 21204
                            I did n`t ask you about the history. Depending on the suffix you might be able to unlock it yourself
                            3.4. Dell
                            Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                            See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                            Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                            Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                            Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                            Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                            Note: There is no publicly available 8FC8 generator available at the moment.
                            The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                            8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                            • FireFox7881
                              • Feb 2023
                              • 6
                              • Poland
                              #694
                              I'm sorry. Ok, thank you very much for the information.
                              • devp62
                                • Dec 2014
                                • 56
                                • uk
                                #695
                                Hi can any one help me clean up this bios pls
                                Latitude 5520
                                ST CFTRZ93
                                3 amber and 6White led flash - Bios corruption detected.
                                • shiyab
                                  • Sep 2023
                                  • 1506
                                  • india
                                  #696
                                  Latitude 5520
                                  ST CFTRZ93
                                  hi try
                                  • Itgigant
                                    • Aug 2025
                                    • Nederland
                                    #697
                                    Could someone help me unlock the bios password for the Dell 5520 i5-11gen
                                    Service tag: g70fpg3-3fe2
                                    Thanks in advance
                                    • minhdigital
                                      • Nov 2022
                                      • 758
                                      • Vietnam
                                      #698
                                      Thanks in advance
                                      Uploald your backup bios
                                      • Itgigant
                                        • Aug 2025
                                        • Nederland
                                        #699
                                        Thanks for the response !
                                        Could you maybe help me ?
                                        how would i get this file for this laptop ?
                                          • 21204
                                          Thread merged. You would need to take apart the laptop and backup the contents of the bios chips using an SPI programmer.
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • Jeff'sTech
                                            Dell Latitude 7420 BIOS Unlock Gone Wrong
                                            by Jeff'sTech
                                            Hello everyone.
                                            I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                            11-08-2023, 03:30 PM
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                            DELL Latitude 5520 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5520 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5520 boardview and 5520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5520...
                                            09-07-2024, 06:38 AM
                                            09-07-2024, 06:31 AM
