BIOS guides, methods, resources and tools — Discussions
This is a sticky topic.
  • Sparo
    Quicksilver
    • Jan 2022
    • 5484
    • M\A
    • Anime, Edge Computing, Football, Snooker
    Originally posted by Stefan Steff
    Tested today on a HP EliteBook 840 G5 and working.
    Thank you !
    You're welcome and thanks for the feedback
    I also needed to confirm it since I typically patch other entries in addition to HPMPM
    Enjoying our forum? Subscribe to unlock extra perks!
    >> Upgrade here <<
    • someonenotyou
      • Feb 2021
      • 82
      • LV
      Hi.
      There is a tutorial on how to clean a corrupt Intel bios, but there is none for AMD.
      Also, I would like to know how do you take DMI information from BIOS dump and apply it to a fresh BIOS without triggering BitLocker.
      Thank you.
      • m1ch43lzm
        • Mar 2019
        • 3530
        • Peru
        1. For AMD, you can get the full BIOS image from the BIOS update provided by the manufacturer, there's no "clean ME region" unlike Intel
        2. Bitlocker decryption key is stored on the TPM, if you flash a clean BIOS (or just a regular BIOS update) the firmware TPM gets reset (Intel ME/AMD PSP); on a normal BIOS update via Windows, Bitlocker gets suspended for 1 count until next reboot for that reason; DMi has nothing to do in this case
        The Bitlocker recovery key (48 digits) should be stored on the Microsoft account, if your customer forgot their MS account details, goodbye data
        For DMI, depends on brand, sometimes it's in plain text, search for the S/N on the original backup with a hex editor and transfer the whole block at the same hex offsets
        For Win license key, search in hex for 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00, transfer the key (including 01 00 00 00 ...) to the same hex offsets
        * Some Lenovo laptops have the DMI and Win key encrypted, search for LENV and transfer the 2 blocks, length 0x2000 starting from the first LENV
        • doivaythoiem
          • Jun 2024
          • 182
          • Việt Nam
          Are there any instructions for the "TPM device not detected" message on a Dell laptop after a BIOS update?
            • 25677
            No, not at the moment.
            • nix30101
              • 41
              Checck the bios settings see if the TPM needs to be re enabled.
              • Sparo
                Quicksilver
                • Jan 2022
                • 5484
                • M\A
                #27
                1. Open the dumped SPI image with the corresponding Flash image tool (FITool)
                2. Go to Build > Build Settings, untick the option to "Generate intermediate build files" and click OK
                3. Go to "Platform Protection > Intel(R) PTT Configuration" section, set all available PTT-related parameters to Enabled/Yes (e.g. Intel(R) PTT Supported, initial power-up state, etc.)
                4. Go to "File > Save As" and save the configuration xml file (the default name is Untitled.xml). Afterwards, close the FITool
                5. Run FITool again. From "File > Open" select the saved configuration xml file and open it. Click the "Build Image" icon (or "Build > Build Image"). This should resolve the TPM error
                P.S: You could also clean the DATA section of the CS(ME/TXE) region while you're at it, if you'd like to.
                > If the initial TPM error persists after the fix, then the TPM chip itself may be faulty and need to be replaced.
                >> Upgrade here <<
              • volinakis
                • Jan 2021
                • 3287
                • N/A
                #28
                About chromebooks ... I noticed if reset or powerwash it (Ctrl + Alt + Shift + r) before reading bios chipset and modify it to unenroll and enable developer mode, there's no need to reinstall OS from USB stick.
                please support this forum
                • munir100
                  • Dec 2018
                  • 200
                  • uae
                  #29
                  how to chromebooks to install windows
                  • volinakis
                    volinakis commented
                    Editing a comment
                    google "mrchromebox" and you'll find extended instructions on his site.
