bios lenovo x395
  • drefo
    • Mar 2021
    • 26
    • France
    bios lenovo x395
    Hello I patched the bios of a lenovo x395 8 generation, but it does not work, I think new security, can you help me? thanks in advance
  • exe557
    • Jan 2021
    • 24
    Re: bios lenovo x395
    Not possible via patching BIOS. You need to read MEC EC chip with RT809 or Vertyanov Programmer to remove password.
    • drefo
      • Mar 2021
      • 26
      • France
      Thank you for your answer, do you have an explained procedure to achieve this? thank you
      • exe557
        • Jan 2021
        • 24
        There are two threads with good information :
        https://www.badcaps.net/forum/showth...&highlight=T14
        • drefo
          • Mar 2021
          • 26
          • France
          Really thank you for your help I will explore all this
          • ymifdal
            • Jan 2022
            • 120
            • Morocco
            x395 password locked
            Hey all I need help regarding Lenovo x395 model "20nms1u800"
            It has a "fa391/fa491 NM-C181 rev 1.0 " motherbard
            patch didn't work, no JTAG unlockable NEC nuvoton on back
            Has got 2 chips on top side 25LB128 and Winbond 25Q8
            • ymifdal
              • Jan 2022
              • 120
              • Morocco
              I mean does anybody know where is the password stored in this model?
              Since patching isnt working so not main bios..
              Also no nuvoton in the back so ??
              • volinakis
                • Jan 2021
                • 2874
                • N/A
                post bios dump and I think i can help you patching it. I was able to unlock an X395 with AMD and 128Mb bios chipset.
                • medinfo
                  • May 2016
                  • 331
                  • Morocco
                  hy, i have same x395 with ryzen cpu, can you help me ?
                • medinfo
                  • May 2016
                  • 331
                  • Morocco
                  Serial Number : PC-1KRLDJ
                  Type Number : 20NM-S1U800​
                  • zinnou
                    • 44
                    • algeria
                    help unlock lenovo X395
                    PC-1J8C33
                    20NM-s31200
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1356
                      • France
                      PC-1J8C33
                      20NM-s31200
                      try
                      • skazide
                        • Jul 2015
                        • 143
                        • morocco
                        PC-1J8C33
                        20NM-s31200
                        salam bro, i tried with vertyanov successor did not success to read , how you did it ?
                        • skazide
                          • Jul 2015
                          • 143
                          • morocco
                          problem solved
                          • ravenrock
                            Hi, I dumped W25Q128FW_1.8V, patched with autopatcher, but when booting with it - melody.
                            Is this the correct chip to patch?
                            If it is the correct one, I would appreciate help.
                            S/N: PC-1DTGB8
                            T/N: 20NM-S0KL00
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12340
                              S/N: PC-1DTGB8
                              T/N: 20NM-S0KL00
                              The password is no longer in the bios chip but in the EC..
                              • ravenrock
                                I was reffering to this thread... supposedly patching BIOS chip worked.
                                https://www.badcaps.net/forum/troubl...-removal/page2
                                • Wahaz
                                  by Wahaz
                                  10-30-2023, 08:42 PM
                                • grimacelord
                                  by grimacelord
                                  Hello there.
                                  History:
                                  03-15-2023, 03:29 PM
                                • to5it0
                                  by to5it0
                                  10-24-2025, 01:35 AM
                                • mkdj
                                  Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                  by mkdj
                                  Dear all,
                                  I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                  Here the steps I have taken to fix the laptop:
                                  - downloaded latest BIOS from Lenovo Website...
                                  10-18-2025, 03:43 AM
                                • jendkkd jeje
                                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                  by jendkkd jeje
                                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                  10-11-2024, 03:12 PM
