Asus X415EA bios file needed
  • bios29
    • Dec 2018
    • 20
    • france
    Re: Asus X415 bios file needed
    Originally posted by bios29
    hello,
    i have an asus x415ea-bv130t which have a bios issue its not detecting the ssd , i tried some bios on the forum and i have one bios who recognize the ssd but no keyboard and other who recognize keyboard but not the ssd
    somebody may have a good bios were i can get the ssd and the keyboard would be appreciate
    here the origin bios extract from the board
    • bios29
      • Dec 2018
      • 20
      • france
      need bios x415ea-bv130t i3 11
      hello,
      Last edited by SMDFlea; 12-21-2022, 03:27 PM. Reason: bios removed already posted it.Why not bump the thread ?
        • 22182
        Re: need bios x415ea-bv130t i3 11
        hello,
        Post the laptop serial number.Do you have a QR code on the board,the same as the one at post 12 with a model number on it
        • bios29
          • Dec 2018
          • 20
          • france
          Re: Asus X415EA bios file needed
          hi , thanks for the answer i will post the serial of the asus and if it has a QR code today
          • pramith
            • Jul 2017
            • 38
            • Sri Lanka
            X415ea main bord r2.0 bios
            X415ea main bord r2.0 inpower
            • saherlct
              • Apr 2022
              • syria
              #26
              thaks
              • bryanpoints
                • Aug 2017
                • 57
                • Philippines
                #27
                Originally posted by SMDFlea
                Try this one .
                thanks you
                • bangben505
                  • Jun 2019
                  • 9
                  • Indonesia
                  #28
                  hallo..
                  can anyone help clear me my bios, its delay display..
                  board code X415 r6.1
                    • 22182
                    Originally posted by bangben505
                    hallo..
                    Read post #23 ,post a picture of your QR code.
                    • Rajputrulers
                      • Jan 2023
                      • 6
                      • india
                      #30
                      Originally posted by correoprueba
                      hi i have an asus x515ea i3 10gen, the motherboard is x415ea r2.0, don't working Asus X515EA - X415EA REV 2.0.bin.zip
                      i also faced same problem, sometime keyboard not working with other bios download. after trying 11th time this bios working good, after programing this bios ,remove hdd for automatic selection of ssd when laptop boot from ssd ,then install hdd again and enjoy
                      X415EA R2.0 WORKING TESTED, after programing go into bios setting ,use default. remove hdd so laptop boot from ssd itself, then intall hdd agian and enjoy
                      • Shalun_avd
                        • May 2022
                        • 11
                        • Украина
                        #31
                        Can try, it worked for me.
                        • rui4892
                          • Mar 2017
                          • 57
                          • Portugal
                          #32
                          Good morning, please correct the original dump (with the original dump the machine turns on and off, without giving an image) or find a compatible dump.
                          I've already tried several dumps, with some not detecting the M2, with others detecting M2 but not detecting the dedicated graphics MX330.
                          The version 2.0 dumps that I tested do not detect the M2, the 6.1 dumps correctly detect the M2 but do not detect the MX330 graphics.
                          Thank you all.​
                          • m.sabry2110
                            • Oct 2017
                            • 134
                            • egypt
                            #33
                            serial number
                            • m.sabry2110
                              • Oct 2017
                              • 134
                              • egypt
                              #34
                              Try
                              • rui4892
                                • Mar 2017
                                • 57
                                • Portugal
                                #35
                                Originally posted by m.sabry2110
                                Try
                                It has almost the same symptoms as the original dump, it turns on and off twice with a consumption of around 15W and turns off once and for all.
                                thank for your answer.
                                • rui4892
                                  • Mar 2017
                                  • 57
                                  • Portugal
                                  #36
                                  serial number
                                  as request MAN0CV16R314420 CN_ZG75
                                    • 22182
                                    Can you find a QR code with a model number on it like this -> https://www.badcaps.net/forum/troubl...90#post1621490
                                    • rui4892
                                      • Mar 2017
                                      • 57
                                      • Portugal
                                      #38
                                      as request, thanks
                                      • rui4892
                                        • Mar 2017
                                        • 57
                                        • Portugal
                                        #39
                                        Thank you all.​
                                        my problem is now solved, I found a dump elsewhere and it is completely functional. I can post on the forum if allowed.
                                        • peste
                                          • Dec 2016
                                          • 13827
                                          • ROMANIA
                                          #40
                                          Of course, post it.. maybe someone will use it for you...
                                          • exerion5000
                                            Bios Needed For Asus X515EA Pcb X415EA R2.0
                                            by exerion5000
                                            Asus X515EA_No Power_GD25B127D@SOIC8.rar
                                            Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                                            02-17-2025, 01:34 PM
                                          • to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                            by to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                            I have opened the laptop and identified the main BIOS chip...
                                            10-24-2025, 01:35 AM
                                          • wakethesleep1111
                                            Bios File Needed for asus tuf15
                                            by wakethesleep1111
                                            Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                                            05-27-2025, 10:56 PM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
