HP BIOS unlock tool
  • Tomcsa
    • Jun 2020
    • 15
    • Hungary
    #621
    Re: HP BIOS unlock tool
    Thank you Peste.
    Then it makes sense why is laptop not turn on anymore.
    But anyway i don't know why it get corrupted, it was working before soldering... maybe this soldering and heat can make it corrupt/fault...?!
    Me as a "knowledge seeker" , can i ask what does mean in names the Orig+n75 and outimage words ?
    Also can i use the "HP UNLOCKER" on this image you sent me to delete bios password?
    Thanks again
    • peste
      • Dec 2016
      • 12254
      • ROMANIA
      #622
      Originally posted by Tomcsa
      Thank you Peste.
      Thanks again
      the bios is made from the original posted by you, and the extract from the update on the Hp site, after which the ME region was cleaned .. has no password ..
      • Mr.customer
        • Jan 2021
        • 5
        • australia
        #623
        hi i have a HP elitebook 820 g1 bios password locked.
        backup bios.bin 10 mb, done with the hp bios setup, create usb recovery usb, there is a folder called current on the usb, i copied the locked bios bin file from that folder. is this a valid backup? or do i have to use a programmer?
        • peste
          • Dec 2016
          • 12254
          • ROMANIA
          #624
          you will need a programmer.
          https://www.youtube.com/watch?v=DWWigscuQDY
          • Tomcsa
            • Jun 2020
            • 15
            • Hungary
            #625
            Originally posted by peste
            the posted bios is corrupt ... try this ..
            Hello Peste,
            First i Wish you happy new year! And for Everyone!
            I forgot to ask you, when you making a bios file like what you sent me (orig+ n75 + outcome), is it matter wich motherboard do i have in my laptop? ( i see 3 different model number MB for 820 g3), or no matters because my corrupted bios dump what i posted contained all these informations?
            I see lot of people when posting their bios dump but they also write next to it their motherboard number too, not only the dump... That's why i am thinking on it, because i did not provided it.
            Thank you.
            Regards,
            Tomcsa
            • peste
              • Dec 2016
              • 12254
              • ROMANIA
              #626
              Hello Peste,
              Thank you.
              Regards,
              Tomcsa
              does the bios sent to item # 621 work ?? if it doesn't work, post the motherboard model ..
              • Tomcsa
                • Jun 2020
                • 15
                • Hungary
                #627
                We could not test it yet, tomorrow i will go to a guy who can proffesionally solder with pro tools, and also He has to repair first the trace paths to the bios chip on motherboard because when i first unsoldering it with my cheap soldering iron i broke it accidently,somehow very easily comes off / peels of the factory copper pads around bios chip. (( so first we repir traces and then we can write new bios you sent me... 🤞
                So tomorrow will be the big day, i pray in advance🤞🤞🤞
                My motherboard number is:
                6050a2892301-mb-a01
                (on a sticker there is a number too: 831765-601)
                • peste
                  • Dec 2016
                  • 12254
                  • ROMANIA
                  #628
                  6050a2892301-mb-a01
                  try..
                  • Tomcsa
                    • Jun 2020
                    • 15
                    • Hungary
                    #629
                    try..
                    Ok, we will first try this second version you just sent to me now.
                    Thank you.
                    • Kilroy2020
                      • Oct 2020
                      • 7
                      I need help with My HP 830-G6. I posted a few months back and now getting back to this project.
                      Can someone tell me which Chips on my HP 830-G6 I need to take off and read-back? I actually have 3 WINBOND EEPROMs on the board and I have no idea which ones are the BIOS. I believe one the main on is on the FRONT side and is the one with the BLUE dot but there are 2 additional EE's on the board and I'm not sure which one I need to read.
                      There is a 256Mb EE (BLUE Dot) on the FRONT of the mother board near the MEMORY, and there are 2 EE's on the BACK of the motherboard, one is U2703 (8MB) and the other has no reference designator but is also 8Mb. Pictures are attached.
                      Any guidance on which ones to de-solder and read out would be greatly appreciated.
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        #631
                        check post #2 i think he have given number of both bios chip
                        https://www.badcaps.net/forum/showth...ight=HP+830+G6
                        • Mr.customer
                          • Jan 2021
                          • 5
                          • australia
                          #632
                          hi, i have problem, i connected the ch134a version 25. to other laptop,
                          connected the usb to clip and to the bios chip
                          always when i press read, it reads and i save and nothing.
                          when i tried press auto, it fails and sais timeout failed.
                          what am i doing wrong? i tought the software should be able to detect it auto?
                          • Kilroy2020
                            • Oct 2020
                            • 7
                            Thanks qayyum786.
                            Can someone check and clean the attached file for Elitebook 830-G6 from my 256MB WINBOND EE?
                            • RethoricalCheese
                              • Mar 2013
                              • 1514
                              • Estonia
                              #634
                              Thanks qayyum786.
                              Read and post the other bios chip.
                              • KnalligerHund
                                • Jan 2021
                                • 4
                                • Austria
                                #635
                                i can't seem to be able to unlock this file or rather the unlocked file does not seem to work, can anyone help? It's from an HP ZBook 15u G2 if that helps.
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1514
                                  • Estonia
                                  #636
                                  try this
                                  • KnalligerHund
                                    • Jan 2021
                                    • 4
                                    • Austria
                                    #637
                                    Now it wont boot anymore, just spinnig fans. Also is it normal that the IC sometimes wont be recognized by AsProgrammer?
                                    • KnalligerHund
                                      • Jan 2021
                                      • 4
                                      • Austria
                                      #638
                                      It feels like I bricked it, any way to restore the BIOS without a working backup?
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1514
                                        • Estonia
                                        #639
                                        Try this then.
                                        • Kilroy2020
                                          • Oct 2020
                                          • 7
                                          Both files are attached.
                                          I really appreciate the help!
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
                                          • iZakre
                                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                            by iZakre
                                            Hello everybody!
                                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                            The thing is that I had installed TeamViewer and could log into the computer...
                                            02-19-2023, 02:27 PM
