HP BIOS unlock tool
Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Re: HP BIOS unlock tool
I tried the unlocker tool and still has power on passwordAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Yes I used Rhetorical Cheese's software V1.0 and it couldn't however i found your post where you uploaded about 5 variants one of their BID matched my dump so yeah that helped me and I was able to use the dmi tool to lock to manufacturing. Thank you all. I will check well maybe I used the HPUnlocker V1.0 insteadLast edited by ajbernasko; 01-13-2023, 03:21 PM.Comment
Never worked on a BIOS lock that isn't Mac, so I'd like to know if this will work with an HP Probook 445 g6.Comment
Thank you very much @RethoricalCheese. I managed to reset my elitebook 850 g2 password using this tool. And thank you for mentioning CH341a and soic8. I actualy use those tools and I know them from your first post in this forum discussion
I just tried the tool to unlock the BIOS password for Probook 5670b. I read the chip with CH341 programmer and used the HP Unlock Tool. Erased and reprogrammed the chip with provided .bin file. Everything went very well without problems.
I did disconnect the bios battery, reconnected and powered on the machine but looks like BIOS is disappeared. F10 doesn't work.
Any ideas what could be probably wrong?
ThanksComment
Many thanks for this amazing tool. Worked great on my admin PW locked HP Probook 6470b. Can also confirm this tool only removes PW - all other data is retained (DMI etc).
Great stuff!Comment
Hey, i have a 455 G8 with remote management, no bios passwords, only can't get passed internet verification. I don't know what to clear/modify in HEX. Please help me with this one, too.Attached FilesComment
https://www.badcaps.net/forum/showth...ProBook+455+G8
Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
hy , can you remove password from this hp 14-dy0502na , 203032-2, SLINKY 1.0 UMA_MB_8L.
i try with admin, try with hp unlocker , try with rcunlocker, dont work
i remove the ssd , so the password is on bios . thanksAttached FilesComment
DMI+KEYWIN 500000 - 50103FDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
I've been trying to remove the passsword from the bios of my Probook 440 G6 with no luck. HPUnlocker won't work in my machine ("cannot execute script it says")
Can anyone help me unlocking it, please?
The dump is attached.
Thanks in advance!Attached FilesComment
RCUnlock worked just fine on this.Comment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by KesavanHello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
Attached my backup file
SERIAL NO: 5CG4300CNT...-
- Loading...
