HP BIOS unlock tool
  • hardware1
    • Sep 2021
    • 2941
    • N/A
    #1381
    Re: HP BIOS unlock tool
    Originally posted by lamo
    hey, guys. have zbook studio g5. dumped ec bios chip. tool said, all is ok. password is still there. I patched second 256mbit chip. password still there. what should I do ?
    Search for your device thread or make your own, upload your both files and someone will help you.
    all donations are welcome,
    • peste
      • 12973
      • ROMANIA
      #1382
      use RCUnlocker on the 16 mb bios..
      • lamo
        • Nov 2017
        • 40
        • Ukraine
        #1383
        ok. here's 16mb dump from this zbook g5. can someone help me? rcunlocker don't work on this dump.
        • hardware1
          • Sep 2021
          • 2941
          • N/A
          #1384
          Here's your Unlocked file, in the first boot go to bios menu and disable security options (Default).
          If the password still present upload your main bios, it could be 16MB or 32MB.
          • lamo
            • Nov 2017
            • 40
            • Ukraine
            #1385
            and the password is still there. i've attached 32mb file to inspect.
            • hardware1
              • Sep 2021
              • 2941
              • N/A
              #1386
              You should program the 2 Unlocked files together and follow the steps that I said before.
              • grecoloi
                • Dec 2010
                #1387
                I just want to thank you for all the info in this thread.
                I successfully removed the BIOS admin password on my HP Elitebook 840 G3 with HPUnlocker and a CH341A (with 3.3v mod) and NeoProgrammer v2.2.0.10 (and a heat gun).
                The Winbond 25Q128FVPQ was the chip to unlock.
                fyi, 'CH341A Programmer v1.30' could not read the chip properly, wheras NeoProgrammer worked perfectly.
                • monolith-2001
                  • Aug 2021
                  • 25
                  • Japan
                  #1388
                  works on elitebook 8730w.thanks!
                  I couldn't use the tools that Mazziff made.
                  https://mazzifsoftware.blogspot.com/...os-unlock.html
                  • lamo
                    • Nov 2017
                    • 40
                    • Ukraine
                    #1389
                    i did this procedure. now, when i'm trying to enter bios setup, i have a message "system locked".
                    • hardware1
                      • Sep 2021
                      • 2941
                      • N/A
                      #1390
                      You have used the both files together? Post an image for the message.
                      • Derhalt
                        • Nov 2018
                        • 7
                        Hi,just tried to unlock my hp 840G5 Bios with thetool from the first page, but it doesn't worked. As there are two IC's which belongsto the BIOS, I'm not sure if I did it with the right one. So question first, is the large 32MB the right one and if yes, is somebody able to do the unlock of my attached one?
                        • Derhalt
                          • Nov 2018
                          • 7
                          Here is the locked BIOS.
                            • 21216
                            Post your request in the 840 G5 bios password thread - https://www.badcaps.net/forum/showthread.php?t=82478
                            • lamo
                              • Nov 2017
                              • 40
                              • Ukraine
                              #1394
                              ok. just managed to get to this unit. here's pic in attachment. I've flashed both chips: 16mb modified with the tool, and 32mb modified by you.
                              • babydoll8867
                                • Nov 2014
                                • 91
                                • romania
                                #1395
                                Hi! I have a 455 G7 clear of passwords but has remote verification i cannot get passed. Can you help me with it? I attach the two dumps, thanks!
                                • peste
                                  • 12973
                                  • ROMANIA
                                  #1396
                                  try this
                                  • babydoll8867
                                    • Nov 2014
                                    • 91
                                    • romania
                                    #1397
                                    Originally posted by peste
                                    try this
                                    unfortunately didn't work... the remote verification still pops up in installer
                                    • babydoll8867
                                      • Nov 2014
                                      • 91
                                      • romania
                                      #1398
                                      I had a similar problem with a 435 g8 and hoaca888 did some magic with the dumps and finally it worked.
                                      • bbanana
                                        Father Land
                                        • Oct 2021
                                        • 164
                                        • Vietnam
                                        #1399
                                        try
                                        • babydoll8867
                                          • Nov 2014
                                          • 91
                                          • romania
                                          #1400
                                          Originally posted by bbanana
                                          try
                                          Same result, unfortunately... Asks for a specific mail in win 11 install... it's weird because in BIOS, there are no signs of security issues, Absolute persistence is inactive...
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
