HP BIOS unlock tool
  • szuts
    • Jul 2022
    • 15
    • Magyarország
    #1321
    Re: HP BIOS unlock tool
    Originally posted by hoaca388
    Were you able to enter the bios settings before the "HP Endpoint Security Controller Problem" message popped up?
    No. I downloaded the original (Eredeti) BIOS, ran the unlock program, wrote back the new content, and started the machine. I started it several times because it was hard to start. When the screen came up, that's what it said.
    Another question: In what order should the battery, the battery, and the adapter be reconnected?
    thx:szuts
    • Gramse
      • Aug 2022
      • sweden
      #1322
      im going out off my mind! can somebody please help me. i have a hp elitebook 745 g5 and i cant get in to BIOS because of password. can someone walk me through it?
      sigpicGramse
      • hoaca388
        Badcaps
        • Jan 2022
        • 11861
        #1323
        First you have to buy a device called "Programmer", learn how to use it, use it to dump the bios file in your bios chip, use the forum's automatic RC unlocker to remove the password, write down the bios file ,which password deleted ,back to the device.
        • Gramse
          • Aug 2022
          • sweden
          #1324
          Okej, guess its kinda like going back to school then. Thanks alot man, really appreciate the help.
          sigpicGramse
          • polymolz
            • Mar 2022
            Hey guys, I have an HP Probook g7 i believe. I had to swap out the motherboard for a client and need to change the serial back to the original. I dumped the firmware but it seems the HP bios is encrypted. I can't locate the serial number in HxD as I can typically do. Is there a method for decrypting the bios so I can change the serial?
            • hoaca388
              Badcaps
              • Jan 2022
              • 11861
              #1326
              Use NbDmiFit : https://www.badcaps.net/forum/showth...light=NbDmiFit
              • magictouch
                • Apr 2021
                • 108
                • united kingdom
                #1327
                I have zbook 15 g3, i have used the hp unlocker tool and it created a unlock file but password has not been removed, can anyone help please.
                  • 21094
                  https://www.badcaps.net/forum/showthread.php?t=72246
                  • zak53
                    • May 2018
                    • 18
                    • Z
                    #1329
                    I used the HP unlock tool with 840 G6 8gen but no success
                    Any help pls ?
                    • RethoricalCheese
                      • Mar 2013
                      • 1518
                      • Estonia
                      #1330
                      Because G6 is supported by rcunlocker, not this old tool. Use rcunlocker on your original EC dump.
                      • zak53
                        • May 2018
                        • 18
                        • Z
                        #1331
                        Thank you but when i drop the 32mb file on rcunlocker i have an error
                        • zak53
                          • May 2018
                          • 18
                          • Z
                          #1332
                          i found it it was in the back of the motherborad
                          • mohammed mohan
                            • Nov 2017
                            • 196
                            • z
                            #1333
                            Thank you
                            Mohammed Mohan
                            • chandrakant
                              • Nov 2017
                              • 39
                              • india
                              #1334
                              Thank u it working
                              • Smeek
                                • Sep 2021
                                • 62
                                • România
                                #1335
                                HP EliteBook 745 G4 TRAVOLTA-6050A2834601 MB A01
                                i have issue with Power-on Authentification
                                here are my original main and EC bios bin, please anyone can clear for me
                                THX
                                • Smeek
                                  • Sep 2021
                                  • 62
                                  • România
                                  #1336
                                  THX
                                  SOLVED
                                  i attach the working bios clean
                                  • teodanci
                                    • Oct 2022
                                    • romania
                                    #1337
                                    thank you very much .
                                    • Gel0@2703
                                      • Oct 2022
                                      • 5
                                      • pangasinan
                                      #1338
                                      Thank You and more power
                                      • attila94
                                        • May 2021
                                        • Svájc
                                        #1339
                                        Hi.
                                        i have 2 zbook 17 g4, i read the bios and unlocked it with unlocker. the laptops turn on but the fans spin 100% and the screen is black. As i was reading the forum i saw in one of the posts that updating the bios solved the problem, can someone do this for me? thanks in advance
                                        • ymifdal
                                          • Jan 2022
                                          • 116
                                          • Morocco
                                          #1340
                                          Hey guys can somebody explain to me why is the password still there even after RCUnlocking the 128 chip.. It's an HP 745 G6
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
