HP BIOS unlock tool
  • ctsemicon
    • Nov 2021
    Re: HP BIOS unlock tool
    Well, I tried both the RCUNLOCKER and HPUNLOCKER. They both acted as though they were successful; both created *_unlocked.bin, but neither one shows any change when doing a compare from original and _unlocked. This is a Zbook 17 G4. If you would, please look at this file that I extracted from BIOS chip and see what might be the issue? Most appreciated in advance, thank you
    • peste
      • 12901
      • ROMANIA
      #1122
      it is not the right bios.. look for another bios chip also with 16MB, it can be on the other side of the motherboard ..
      • ctsemicon
        • Nov 2021
        Right you are! Was under keyboard. Thank You very much!
        • dani981
          • Mar 2018
          • 89
          • Hungary
          #1124
          I tried HP Unlocker v1 not unlock password. I think the manual HXD Editor replace the copy clean UserCred section with the same length from another file. The password is back!
          Please help unlock.
          HP 840 g5 Computro-6050a2945601-mb-a01
          Original bios file
          • peste
            • 12901
            • ROMANIA
            #1125
            Please help unlock.
            Original bios file
            try..
            • dani981
              • Mar 2018
              • 89
              • Hungary
              #1126
              Originally posted by peste
              try..
              Thank you Peste but not started, power on led blink.
              • dani981
                • Mar 2018
                • 89
                • Hungary
                #1127
                This code replace nv ram?
                • pirusvlad
                  • Apr 2021
                  • 13
                  • uk
                  #1128
                  here m8
                  • alecocr20
                    • Apr 2020
                    This worked as expected. For information I was able to dump and write the bios using a teensy ++2.0 that I used in the ps3 days. What was needed:
                    Teensy ++ 2.0
                    Python 2.7.2
                    Pyserial 2.5
                    Teensy Loader
                    SPIway.py (from PS4 Devwiki git) this needs to be modified if the actual chip is not already there
                    SPIway.hex (also from PS4 Devwiki git)
                    Thanks again for this tool
                    • zdrawkocolic
                      • Dec 2021
                      • Serbia
                      #1130
                      Hi All...
                      I just try to unlock my BIOS (HP EliteBook 820 G1)...
                      After flashing I do not have an option to go to BIOS anymore. F10 does not take an effect, just windows booting...
                      Can anybody help me?
                      • zdrawkocolic
                        • Dec 2021
                        • Serbia
                        #1131
                        Here it is my .bin file
                        • RethoricalCheese
                          • Mar 2013
                          • 1518
                          • Estonia
                          #1132
                          Use shift-restart in Windows.
                          • alexmonk63
                            • Dec 2017
                            • 14
                            • Plzen
                            #1133
                            Thanx
                            • Tjaytony
                              • Oct 2020
                              • 114
                              • Nigeria
                              #1134
                              I'm sure if I read through this thread well, I'd be able to figure it out. But why don't the creator of this thread make a YouTube video of this procedure. That will redirect people to this website/forum
                              • sharkice
                                • Aug 2020
                                • Argentina
                                #1135
                                Hello, sorry for my English, I want to unlock the bios of my Elitebook 840 g1, it has a 25q128fv chip 3.3 volts, I use neprogrammer 2.2.0.10 with ch341a, it detects the bios, I read it, I use the HPUnlocker program, charge The new bios generated by the program, I record it on the elitebook g1 and it still appears to me that the bios has a password! ??? any ideas or can someone check that the file is unlocked fine? Thank you !!
                                • sharkice
                                  • Aug 2020
                                  • Argentina
                                  #1136
                                  hpunlocker WORKS PERFECT !!!!
                                  elitebook 840 g1 and g2, it needs power to be able to maintain the 3.3 volts, the form was the following with which it can correctly read the bios
                                  With some programmers, you must do this:
                                  * Remove the battery
                                  * Connect the charger
                                  * Turn on the laptop and go to F1, F10 or wherever you want
                                  * Turn off the laptop by pressing and holding the power button (DO NOT REMOVE THE CHARGER)
                                  * Connect the programmer
                                  * Read the content bios chip
                                  * Use the check function or read the content one more time and compare using hex editing software
                                  * If everything is ok, use the HPUnlocker tool on the VERIFIED BIOS dump
                                  * Write the file xxx_unlocked.bin
                                  * Check BIOS content
                                  You should always make sure to check everything you read / write, I cannot stress this enough.
                                  And those first steps are a must with some programmers unless you unsolder the chip.
                                  THANKS to the forum for the messages, with your help you can unlock the bios of these two elitebook g1 and g2 840 !! Cheers ! and good end of the year to all !!!
                                  • Adi13089
                                    • Oct 2017
                                    • Polska
                                    #1137
                                    Looking for help removing the BIOS password on a HP Probook 6360b
                                    • peste
                                      • 12901
                                      • ROMANIA
                                      #1138
                                      read post # 1.
                                      • Adi13089
                                        • Oct 2017
                                        • Polska
                                        #1139
                                        read post # 1.
                                        Not working.
                                        Nothink change in dump file.
                                        • peste
                                          • 12901
                                          • ROMANIA
                                          #1140
                                          Not working.
                                          try..
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
