HP BIOS unlock tool
  • max67
    • Jan 2020
    • 5
    • France
    #61
    Re: HP BIOS unlock tool
    I just did it alone, downloaded the hp unlocker (under the 1st page of the treat) and just drop my bin and it worked like a charm, thks for your help ;-)
    My laptop works again
    If my bin unlocked can help another one
    • RethoricalCheese
      • Mar 2013
      • 1517
      • Estonia
      #62
      Good job!
      Everybody should use their own dump files, otherwise there could be problems like errors, slow boot or wrong dmi information like serial number.
      • hallo51
        • Sep 2019
        short question, this tool only removes the password and does not touch anything else in the BIOS dump ?
        Best,
        hallo51
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #64
          Best,
          hallo51
          Еxactly.
          Become a Badcaps supporter
          Thanks to all supporters.​
          • gabucis
            • Oct 2019
            • 13
            • united kingdom
            #65
            Hell i have created dump with ch341a programmer
            then unlocked with this unlock tool flashed it back but now only fans spin at full
            speed and nothing on the screen i have attached files can someone please check .
            Thank you
            • RethoricalCheese
              • Mar 2013
              • 1517
              • Estonia
              #66
              Thank you
              Because sadly your dump is missing most of its content.
              • gabucis
                • Oct 2019
                • 13
                • united kingdom
                #67
                What to do now?
                • gabucis
                  • Oct 2019
                  • 13
                  • united kingdom
                  #68
                  How could that happen programer was reading ok just had some write timeout error in programmer software but after couple times it was writing fine. Any ideas why that happened?
                  • RethoricalCheese
                    • Mar 2013
                    • 1517
                    • Estonia
                    #69
                    It had nothing to do with writing. When you read eeprom content, some of the information was lost. Didn't you verify your dump?
                    You need a working dump from somewhere with clean ME. Not sure about this model but with some models, there is DMI information on EC bios so when you program main bios with wrong information, it will automatically replace it with correct information.
                    HP bios can get complicated, I am having trouble myself with some models.
                    • gabucis
                      • Oct 2019
                      • 13
                      • united kingdom
                      #70
                      this is Elitebook 1030 G2 when i reed chip i just made 3 backups thats all i have attached other 2 how can i check if they are good or bad ? also which is the main bios because i was flashing 16mb chip but there is also 8gb one
                      • ibo
                        • Oct 2019
                        • 93
                        • Turkiye
                        #71
                        I can confirm this tool works also for the elitebook 1040 x360 G6
                        • RethoricalCheese
                          • Mar 2013
                          • 1517
                          • Estonia
                          #72
                          You can't read it anymore because you already wrote a faulty dump on it. Basically deleted some of the content.
                          Try this:
                          • gabucis
                            • Oct 2019
                            • 13
                            • united kingdom
                            #73
                            Try this:
                            Now i have 3 long beeps and 2 short
                            • gabucis
                              • Oct 2019
                              • 13
                              • united kingdom
                              #74
                              Try this:
                              i have flashed bios with that file verified its matching but now laptop boots up keyboard flashing and after its producing 3 long and 2 short beeps fans starts to spin at full speed nothing else black screen also have tried different bios files from other forum members same thing. Any ideas what to try next?
                              • RethoricalCheese
                                • Mar 2013
                                • 1517
                                • Estonia
                                #75
                                No idea, sorry. Make a new topic about it and maybe someone knows how to help.
                                And next time don't forget to verify when you read the original dump.
                                • peste
                                  • 12314
                                  • ROMANIA
                                  #76
                                  try this..
                                  • tlfrance
                                    • Jan 2020
                                    • 18
                                    • france
                                    #77
                                    I would like to remove bios pwd on my 840 g3 . It’s wson8 chip and have gold plated contacts near the bios chip (mx25L12873F).
                                    1/ Is ch341a programmer is compatible for dumping / writing the chip?
                                    2/ Is it possible to do that without desoldering the chip and solder wires directly on the contacts near it?
                                    Thanks for help
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1517
                                      • Estonia
                                      #78
                                      Originally posted by tlfrance
                                      I would like to remove bios pwd on my 840 g3 . It's wson8 chip and have gold plated contacts near the bios chip (mx25L12873F).
                                      Thanks for help
                                      Yes, try soldering wires. I always desolder wson8 chips but soldering wires to gold pads should work exactly like using a soic8 clip on soic8 chips. Don't forget to verify your dump.
                                      • tlfrance
                                        • Jan 2020
                                        • 18
                                        • france
                                        #79
                                        Thanks for help. I saw 2 different ch341a programmers (black pcb and green pcb) . Difference seems around voltage (5v for black , 3,3 v for green). Which one should I take?
                                        • GabTal
                                          • Jun 2019
                                          • Italia
                                          #80
                                          Hi everyone, i need help.
                                          I have a second-hand elitebook 850 g1 with bios locked by password.
                                          Understood that i need to unlock the BIOS is the ch431a programmer+soip8 with the software to dump my own bios file, to reprogram it and at last flash it. But i see on the motherboard two chips. Which is the correct one? I need to reprogram both bios?
                                          I've attached the img to be more clear.
                                          Thanks everyone
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
