HP BIOS unlock tool
  • N0f3ar
    • Oct 2016
    • 51
    #921
    Re: HP BIOS unlock tool
    hi i tried to unlock 8440p .The unlocker generated file_unlocked.bin , but it did not work.
    Please help
    • Seattle2021
      • Jun 2021
      • 19
      Hi, I have attached a zip file containing the original locked main(25Q128) and secondary(25Q16) BIOS files from the 1040 G2. Please let me know if you need additional information. Thank you so much for your help
      • peste
        • 13377
        • ROMANIA
        #923
        use the program from post # 1 on the 16MB bios, the other bios remains the same ..
        • hopey
          • Aug 2019
          • 5
          Hello Together,
          I have a ZBook 15 g1. I desoldered the chip and read it via linux. Used the tool of post #1 and got a _unlocked file.
          Sadly the _unclocked binary is binary identically to the original one
          What went wrong? Is there another possibility to unlock the bios?
          • imranromi
            • Jan 2015
            • 1290
            • Pakistan
            #925
            Originally posted by hopey
            Hello Together,
            What went wrong?
            I attached the files. Maybe someone is able to patch it for me or you can help me how to?
            Try this.
            • hopey
              • Aug 2019
              • 5
              Originally posted by imranromi
              Try this.
              Thanks, but beyond compare shows me a completely different content
              I'm not even sure to have the same serial number anymore
              • imranromi
                • Jan 2015
                • 1290
                • Pakistan
                #927
                Thanks, but beyond compare shows me a completely different content 🙄 I'm not even sure to have the same serial number anymore 😐
                Correct i fix board 10 mint before your i read post.I read bios chip via programmer and sent you
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1317
                  • France
                  #928
                  look
                  • hopey
                    • Aug 2019
                    • 5
                    Hello Together,
                    soldered the bios chip back in - they seemed to forget the password on this 🙈 ...and I did not check it 🙄 epic fail!
                    • Seattle2021
                      • Jun 2021
                      • 19
                      Hi Peste, I flashed the "unlocked" BIOS file for the 16MB chip following the instruction on page #1, but I am getting the 5 flashes of the Cap and Scroll keys. I did this on a new BIOS chip as well as the original BIOS chip. Fortunately, I was able to boot up normally after flashing the original locked file back to the original BIOS chip. Please let me know if you have any suggestion. Much appreciated. (Attached is the unlocked file using the HP unlocked tool)
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #931
                        Would you be kindly unlock this BIOS file from a HP 1040 G2?
                        BIOS chip is a Winbond W25Q128FV.
                        For some reason I also get a "Failed to execute script Unlocker" error when attempting to unlock the bin file. Thank you so much for your help
                        Hi, do you know if you need to unlock both BIOS on a 1040 G2? I am not getting any display and flashing Cap and Scroll keys when I only unlocked the 25q128fvsq BIOS chip. Thank you for all your time and support.
                        HPUnlocker doesn't work with 1040 G2 unfortunately, so there is no point to keep trying, not going to happen.
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                        • Seattle2021
                          • Jun 2021
                          • 19
                          Thank you for this information about HPUnlocker. Is there another solution to unlock the password Thanks
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #933
                            You have already asked Peste for help, just be patient and wait for him to rebuiild your bios dump, than use HP dmi tool to write back the serials etc. and that's all.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1317
                              • France
                              #934
                              try
                              1040 g2 contains scancodes not AdminPW in 16 mo chip
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1317
                                • France
                                #935
                                Please help
                                same as above
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #936
                                  Originally posted by Maxpower3
                                  try
                                  ... and health issues with P.R.O.S.t.a.t.e.
                                  Just joking
                                  Good work Maxpower3, should work fine.
                                  • Seattle2021
                                    • Jun 2021
                                    • 19
                                    try
                                    Hi Mazpower3,
                                    I have just tried your latest patch but I still get the blank screen display, (5) flashing scroll & cap lock, also high fan speed. Please let me know if I need to make additional tweak to make this work. I also make a mistake previously as this is a 1040 G1 and not G2 according to the system info. Thank you again for all your time and support. You have a wonderful day
                                    • peste
                                      • 13377
                                      • ROMANIA
                                      #938
                                      try..
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1317
                                        • France
                                        #939
                                        Hi Mazpower3,
                                        retry with new file
                                        weird should work fine normally ??
                                        your solder is good ,not clip with read and write
                                        • Seattle2021
                                          • Jun 2021
                                          • 19
                                          retry with new file
                                          Maxpower3,
                                          Thank you for keep trying.
                                          With the latest patch, I get a different result, the Power and Cap LEDs are lit, but the screen is blank, and fan does not turn on. I also did a file comparison after write/read of the new file on the BIOS chip.
                                          I don't use clip on the EZP2019 program, only soldering.
                                          I am pretty sure it's not a soldering issue or programing issue since the laptop works fine when I restored the original code back onto the BIOS chip. Again, really appreciate for all your time in getting this to work.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
