HP BIOS unlock tool
  • Domi93
    • Mar 2021
    • Österreich
    #721
    Re: HP BIOS unlock tool
    I always get the attached Error. I put the exe and the file from Chip directly to C:/ but still no change. What could be the Problem?
    • koxan
      • Mar 2021
      • russia
      #722
      Hp elitebook 830 G5.
      I am writing via google translator, so sorry for the mistakes.
      What chips need to be soldered and from which to write off information, I have three of them?
      After I read the chips, can I modify them via HPUnlocker_v1?
      • shabi
        Banned
        • May 2019
        • 147
        • pakistan
        #723
        Is that available hp unlock tool v2
        • koxan
          • Mar 2021
          • russia
          #724
          Please unblock .... HP 830 G5
          • Serg5555
            • Apr 2020
            • 13
            • Belarus
            #725
            try
            • tiamoface
              • Jan 2019
              • 7
              #726
              Guys, reprogrammed both chips on hp elitebook 840 g6 and all i get is 7 short caps lock + num lock flashing beeps. Power led always on. Any idea please?
              • Rockton
                • Dec 2020
                • 27
                For the BIOS dump. Im having some issues. No matter how I try to read it with the 341 programmer with software Asprogrammer with both ver 1.4 and 2.0. Every read of the chip brings up all FF FF ..
                I am not sure if the chip is encypted to show this or if the chip is bad.. or if the issue is with the connection. the chip is on the circuitboard, battery is out of laptop, and its not plugged into the charger.
                • peste
                  • 12295
                  • ROMANIA
                  #728
                  the bios chip must be removed from the motherboard, for a correct reading and writing ...
                  • Eddie_Dredd
                    • Mar 2021
                    Hi! Thanks for your great work! Can someone please help me with ProBook 650 G5?
                    • tiamoface
                      • Jan 2019
                      • 7
                      #730
                      Originally posted by peste
                      try..
                      Originally posted by tiamoface
                      Hi Gents,
                      Can you help please with HP EliteBook 840 G6 bios password removal?
                      Tried to remove and soldered chips back on the motherboard but now just caps lock always on and blank screen.
                      Attached 2 original dumps 16mb wson-8 and 32mb.
                      Thanks in advance!
                      Tried 2 times, flashed and verified both. all i get is 7 flashing Caps lock + Numlock. Any idea please?...
                      • Emifix
                        • Mar 2021
                        • 5
                        • Nigeria
                        #731
                        Originally posted by RethoricalCheese
                        You can contact me by writing here, by sending me a personal message or by sending me an email through my profile here (click on my name -> send email).
                        I am working on some more tools, will try to post them aswell when I get them finished.
                        Pls I need the utility tooks to unlock my hp bios.
                          • 20412
                          Have you taken the time to read post #1 ? .
                          • tim9
                            • Feb 2021
                            • 11
                            you have probably read or written the bios chip with errors ... post the bios backup ..
                            I did bios upgrade 1.51 after password unlock. It was working fine but after couple hours it started behaving weird. So I thought it might be soldering fault and tried to heat up the chip with no success. I was able to backup 1.51 backup from the chip but I feel that its corrupted based off comparison with another laptop backup.
                            I am attaching it here.
                            So far I tried older bios version 1.39 unlocked backup but nothing worked.
                            Same LED blinking pattern that shows logic board failure.
                            • peste
                              • 12295
                              • ROMANIA
                              #734
                              the posted bios is empty ... post the name and the complete model of the laptop, and the model of the motherboard..read the bios chip again and post ..
                              • peste
                                • 12295
                                • ROMANIA
                                #735
                                Try..
                                • majdkh
                                  • Mar 2021
                                  • morocco
                                  #736
                                  hi from morocco can you please show me howw to unlook my bios hp elitebook 840 g3 pleaseeeeeeeeeeee
                                    • 20412
                                    Use the HPUnlocker at post #1 ,read the instructions.
                                    • tim9
                                      • Feb 2021
                                      • 11
                                      Oh BIOS is empty, I think that's the issue. I am not able to read the chip now , It seems damaged. My programmer reads another Winbond chip but not this one.
                                      I have old bios 1.13 backup. I am attaching here.
                                      Requested information :
                                      Model : HP EliteBook G3 Touch i5 6200
                                      Logic Board : 6050A2892401-MB-A01
                                      • brise
                                        • Mar 2021
                                        • Ger
                                        #739
                                        Hp 840 g2
                                        HI,
                                        i could not write my new bios.bin to my chip because AS Programmer says;
                                        "Possible protection ist enabled. Press unprotect....."
                                        I pushed the unprotect button three times with no result. What ist wrong?
                                        I use the ch341 programmer
                                        Please help
                                        • peste
                                          • 12295
                                          • ROMANIA
                                          #740
                                          try this..
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
