HP BIOS unlock tool
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    #641
    Re: HP BIOS unlock tool
    try
    • KnalligerHund
      • Jan 2021
      • Austria
      #642
      Originally posted by RethoricalCheese
      Try this then.
      This worked, thank you very much. However now i get the message "machine is not in committed state" when booting. Any way to remove that?
      • techman1025
        • Jun 2014
        • 497
        Use HP DMI tool
        Techman1025
        • formingus
          • Oct 2019
          • Albania
          #644
          HP 6730S work gr8. Confirmed
          • jacospama
            • Aug 2019
            • 240
            • Ghana
            #645
            (For those of you who need to unlock large amounts of laptops, I recommend adding a registry entry: )
            Thank you Senior. please i dont know how to add registry. please teach me how. thank you
            • abrueda
              • Jan 2021
              • argentina
              #646
              Originally posted by danito
              hi,
              HP 820g4 i5-7200u
              try with HPUnlocker and caplock & numlk led x5 and fan max.
              Me too, 820 G2, only 128Mb flashed (EC still origin IC).
              • qayyum786
                • Aug 2018
                • 1959
                • INDIA
                #647
                Originally posted by abrueda
                me too, 820 g2, only 128mb flashed (ec still origin ic).
                try
                • abrueda
                  • Jan 2021
                  • argentina
                  #648
                  Originally posted by qayyum786
                  try
                  Thank you so much. But it doesnt work.
                  I have original IC mx25l12873fm with original BIOS, y dont flash it because I'm afraid it won't work if I reprogram. Instead i bought new ic 25q128fv and i flashed original BIOS unlocked (through hp utility and this one you posted), but still capslock blinking and fan on.
                  Even i flashed original bios readed from original elitebook 25l12873fm and program on new 25q128fv but no luck.
                  Maybe ICs are not compatible?
                  I try read and write several times and compare with winmerge. (By the way bios trough hp utility is not equal that you posted)
                  Im using ch341a black with 3.3 voltage fix, SO8 clamp (desoldered) and Neoprogrammer under Win10.
                  Thanks!
                  Edit: EC IC is original, i dont touch it. If i solder original bios IC back again, laptop works fine (locked)
                  • qayyum786
                    • Aug 2018
                    • 1959
                    • INDIA
                    #649
                    Try
                    • abrueda
                      • Jan 2021
                      • argentina
                      #650
                      finally i have solve my problem , im not sure if this solution has been discussed here: the original latop IC BIOS is working in Quad SPI mode (or QPI), so QE (Quad enable) bit must be enable. i locked up QE bit from the datasheet (status register) of new BIOS IC and enabled it from AsProgrammer.
                      • bsz
                        • Feb 2020
                        • 5
                        #651
                        Hi, I tried HP unlock tool, but still asks for the password.
                        The laptop is HP elitebook 830 G6.
                        I attached the two files.
                        Thanks.
                        • peste
                          • 13370
                          • ROMANIA
                          #652
                          Thanks.
                          try..
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            #653
                            Thanks.
                            Try this (128Mb chip only)
                            When you access bios, reset security settings to default.
                            • LatinMcG
                              • Jun 2015
                              • 73
                              • USA/Puerto Rico
                              #654
                              Hi RethoricalCheese!
                              from what ive learned about the G6 all it needs is
                              blank VSS 32 MB and clean pwd 16MB.
                              flash both and pwd gone.. then flash 32MB original w PWD and it clears itself from 16MB recovery and DMi preserved w no pwd.
                              maybe that will help the V2 release?
                              • Kodza
                                • Jun 2016
                                • 191
                                • South Africa
                                #655
                                Thanks man for a great tool, really appreciate
                                • Crizby
                                  • Mar 2018
                                  • 12
                                  • N/A
                                  #656
                                  Hi. Any chance anyone could remove the password from my HP 850 G5 Bios.
                                  I think I have removed the correct chips. One is a WINBOND 25Q256JV and the other is a ISSI IC25LP128. I have attached the files from them. Thanks
                                  • Phaseshift
                                    • Jan 2021
                                    • 5
                                    • Philippines
                                    #657
                                    Hi Rethorical cheese could you help me with my HP Elitebook 840 G7 with processer of intel i5 10gen i tried to flashit it but i get an error "error code address: 0x000003 Buf_Val:0C IC_Val:0x04"
                                    • Phaseshift
                                      • Jan 2021
                                      • 5
                                      • Philippines
                                      #658
                                      • fatguy1121
                                        • Jan 2021
                                        Hey guys, is there a trick to getting good data out of the W25Q256JV bios chip on an Elitebook 840r G4 in circuit? I must have read it half a dozen times each with random bits flipped. Once I manage to reliably read the data I guess I'll post it for RethoricalCheese to modify unless there is something I can do myself?
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #660
                                          No need to spam everywhere, it doesn't make me answer faster
                                          You would need to desolder the chip to make reading/writing more reliable.
                                          And this version of the tool does not support your laptop.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
