HP BIOS unlock tool
  • msdalaa
    • Oct 2017
    • Sweden
    Re: HP BIOS unlock tool
    Originally posted by RethoricalCheese
    Just used it and works fine.
    Did you put HPUnlocker.exe in C:\ or D:\ directory? If your directory has spaces or maybe some strange letters in it, it will give the error you wrote as I wrote before.
    Thaaaaaankxxxx man its work perfect
    it was my fault . i have to drag bin file directly to your tool file not to open the tool file .
    Thank you so much.
    • bachir2004
      • Feb 2015
      • 437
      • maroc
      Originally posted by bachir2004
      thanks for the nice work i really appreciate.
      Will give feed back on every test.
      works on elitebook 840 g2.thanks!
      • bachir2004
        • Feb 2015
        • 437
        • maroc
        Used the tool for probook 650 g3 .no boot!SORRY WAS BADF CHARGER.
        • xerano
          • May 2019
          • 10
          • Deutschland
          can i use some BIOS Backup Tools to get the dump from a EliteBook 840 G1?
          i tried with Universal BIOS Backup Toolkit 2.0
          can u check this for me please?
          • RethoricalCheese
            • Mar 2013
            • 1518
            • Estonia
            But there is no point in doing it like that. You can't program eeprom without using a SPI programmer anyway. So just get a programmer and read it with that.
            The other way would be decrypting the password but good luck with that (and share knowledge if you succeed )
            • xerano
              • May 2019
              • 10
              • Deutschland
              #26
              My Problem is, that i tried serveral Times to dump the BIOS with the CH341a Programmer and all dumps are faulty.
              The question is, can someone Check my dump that i created with the Tool. will this dump Work to Flash them?
              • RethoricalCheese
                • Mar 2013
                • 1518
                • Estonia
                #27
                Then you need to deal with why it turns up faulty. If you can't read properly, you can't write properly.
                What you have to do is:
                *Disconnect battery
                *Connect charger
                *Turn on laptop (Go to F1 screen or whatever you like, doesn't matter)
                *Turn off laptop using the power button and DO NOT disconnect charger
                *Attach soic8 clip to eeprom
                *Read bios.
                *Mod bios.
                *Write bios.
                Turning laptop on and off is very helpful on HP-s.
                • xerano
                  • May 2019
                  • 10
                  • Deutschland
                  #28
                  *Disconnect battery
                  *Connect charger
                  *Read bios.
                  *Mod bios.
                  *Write bios.
                  Okay i give it a try i will Report soon thank you in advance
                  • xerano
                    • May 2019
                    • 10
                    • Deutschland
                    #29
                    Can i use a SOIC8 DIP Socket Adapter too? I would desolder the IC
                    • zmedia
                      • May 2018
                      • 62
                      • Algerie
                      #30
                      please help me
                      i have windows 64bits
                      thank u
                      • xerano
                        • May 2019
                        • 10
                        • Deutschland
                        #31
                        okay i have desoldered my chip and dumped it with AsProgrammer 1.41 and CH341A Programmer
                        then i used the HPUnlocker Tool and flashed this Image to the Chip (i ereased the Chip before)
                        now i have only black screen and Blinking CapsLock Key (5 times blinking)
                        can someone check my dumps to verify please?
                        Thank you
                        • RethoricalCheese
                          • Mar 2013
                          • 1518
                          • Estonia
                          #32
                          Originally posted by zmedia
                          please help me
                          thank u
                          Are you trying to open it or did you read first post and tried dragging locked file on .exe file?
                          • xerano
                            • May 2019
                            • 10
                            • Deutschland
                            #33
                            @RethoricalCheese please Help me
                            • razor_amd
                              • Sep 2013
                              • 77
                              • Serbia
                              #34
                              Thank you
                              Here you are
                              After programming, Power on laptop and let it power cycle a couple of times. This is CleanME BIOS also so you need to wait for it to finish everything...
                              • zmedia
                                • May 2018
                                • 62
                                • Algerie
                                #35
                                i traying to open it
                                • zmedia
                                  • May 2018
                                  • 62
                                  • Algerie
                                  #36
                                  even if I drag the file lock it's not working
                                  except it does not use function under windows 10
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1518
                                    • Estonia
                                    #37
                                    Do you have spaces or other odd characters in file name or directory?
                                    • zmedia
                                      • May 2018
                                      • 62
                                      • Algerie
                                      #38
                                      no i dont have spaces or other characters
                                      • xerano
                                        • May 2019
                                        • 10
                                        • Deutschland
                                        #39
                                        Originally posted by razor_amd
                                        Here you are
                                        Okay i try it tomorrow i must desolder it again.. No Clip only Dip Adapter 😅
                                        • xerano
                                          • May 2019
                                          • 10
                                          • Deutschland
                                          #40
                                          Here you are
                                          THANK YOU SOOOO MUCH!
                                          have u only use the HPUnlocker Tool? i have 2 another Elitebooks can i use this tool to done this?
                                          or have u special mod used?
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
