HP BIOS unlock tool
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    #441
    Re: HP BIOS unlock tool
    Originally posted by RethoricalCheese
    Well, you need to specify which model you have. BIOS chip models don't say much.
    sorry for late reply
    hp omen 15 ax236tx laptop
    error: 5.3 capslock blink error,
    system board is ok, flashed bios chip with 08217 bin file but not sure do we have to unlock it before flash or is it ok to flash without unlocking?
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #442
      Omen not supported. Make a new topic about it.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        #443
        Hi
        need help ,
        My hP omen laptop ax236tx model has stopped working . No display only capslock blinking 5 long 3 short. I have checked ram and reset cmos and did every thing which links with this code, flashed bios chip using soic8 clip adapter and SPI programmer using help from this forum.
        Can someone check my bios file what is wrong with this file, do it needed to unclock or not. i retrieved this file from my laptop bios chip Gigadevice GD25B64CS1G
        thanks for help. I am stuck
          • 21626
          Originally posted by stingerchamp
          Hi
          need help ,
          Didn`t you read post #442 .Your bios has been deleted,you`ve already posted it in another thread.
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            #445
            Sorry , It will never happen again But my concern was does my laptop model will get benefit from HP bios unlocker or no need of it
            please help me to solve this OMEN laptop no display issue.
              • 21626
              The HP BIOS unlock tool is a bios password unlocker,it will only remove bios passwords for certain HP models,not pavilions,not omen models either.This tool will not help with a black screen issue.
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                #447
                Thank YOU Understood.
                Please help to check file i posted in another thread.
                • Mugatu
                  • Sep 2020
                  • 7
                  • Sweden
                  #448
                  I am really not sure. Too new for me so I have not tested it on that model yet.
                  Thanks. Since the model was released around the same time as laptops with 8000U CPU's I guess there's hope at least.
                  Is Sure Start a problem for using the method in the OP? Generally speaking.
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #449
                    Haven't had an issue with surestart yet.
                    You should factory reset settings and security settings after restart. This should make it like it was never locked before.
                    • Mugatu
                      • Sep 2020
                      • 7
                      • Sweden
                      #450
                      Ok, good to know. My 645 G4 have both Surestart and BIOS password enabled.
                      I was worried because Sure Start is supposed to restore the BIOS (I guess copied from the other chip) if certain conditions are met.
                      • eric_locate
                        • Oct 2020
                        • 9
                        • uae
                        #451
                        it's not work in Elitebook 830 G5 , plz help...
                        • eric_locate
                          • Oct 2020
                          • 9
                          • uae
                          #452
                          Originally posted by itsmagic1
                          The tool works great for a HP 830 G5. It unlocks my Administration Password!
                          Thanx a lot!
                          can show me how u fixed it, i have same model but it not work..
                          • eric_locate
                            • Oct 2020
                            • 9
                            • uae
                            #453
                            that's 2 file bios i found in motherboard
                            plz help...
                            • peste
                              • 13357
                              • ROMANIA
                              #454
                              plz help...
                              try this if it works enter the DMI information
                              • RethoricalCheese
                                • Mar 2013
                                • 1519
                                • Estonia
                                #455
                                I assume this loses serial number and other data and laptop will be in MPM?
                                • eric_locate
                                  • Oct 2020
                                  • 9
                                  • uae
                                  #456
                                  i tried 2 file but it's not working , then i kept file 32M orig + file 16M (you fixed) -> it's work -> bios password removed
                                  But have a problem -> security device
                                  you have any solution , thanks
                                  • peste
                                    • 13357
                                    • ROMANIA
                                    #457
                                    try again with what I sent you to post # 454, the 33mb bios posted by you is longer, it can't work ... and be careful when writing ...
                                    • grzesiek3108
                                      • Jun 2019
                                      • 10
                                      • Poland
                                      #458
                                      Hi 8470p (3rd gen) issues. Winbond 25Q128 16legs chip.
                                      When i use tool and put new dump i have black screen, no power at all.
                                      Rollback and working fine so dump is ok. Any ideas? Ive got only problem on two this models.
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1519
                                        • Estonia
                                        #459
                                        Share your files, can't help blindly.
                                        • techcare
                                          • Nov 2017
                                          • 18
                                          • KOREA
                                          #460
                                          Is this working in HP Probook 6470b?Thanks
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
