HP BIOS unlock tool
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #421
    Re: HP BIOS unlock tool
    Originally posted by RethoricalCheese
    ...No Pavilions or other trash is supported ...
    Become a Badcaps supporter
    Thanks to all supporters.​
    • lucifer676767
      • Oct 2014
      • Greece
      #422
      Thanks for your hard work. HP Elitebook 820 G3 works
      • kanofski
        • Oct 2016
        • 14
        • holland
        #423
        Originally posted by dewako
        My laptops have two password administrator and power on password i removed administrator password but power on password still there please help..
        try this.. let me know if it works or not ..
        • moitoinous
          • Sep 2020
          • 5
          • US
          #424
          (...) you need to dump your bios, remove password from dump and reprogram bios with modified dump.
          For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
          When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
          Just program the new file on your bios IC.
          This unlocker should work on all Elite, EliteBook, ProBook and maybe some other series HP laptops.
          Used CH341A USB programmer and in-circuit programming clip.
          Successfully removed BIOS password with HP Unlocker on the following
          ProBook 6470b
          ProBook 6570b
          • kingsco
            • Sep 2020
            thanks for this useful thread
            have hp elitebook 840 G3 can anyone help please
            sorry for my ignorance but i just made a look at the website so the steps to unlock the bios password is to get a dump of the bios soft and use a tool to clear the password then reprogram the bios
            i'm stuck at the first step make a bios dump\any tutorial here or video
            thank's
            ++++ geek
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #426
              You first need a tool for that. Raspberry pi, minipro, Ch341A, tl866 or any other SPI programmer. Then unsolder the chip and attach it to programmer. Read, modify, write. Then solder it back to motherboard.
              • kingsco
                • Sep 2020
                I have a raspberry pi 3, is there a video on the forum on how to unsold the chip
                is there a way how I can get the bios dump and modify it without unsolder the bios chip ?
                ++++ geek
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #428
                  No, not on your model. If you need to ask how to unsolder it, it would be faster and cheaper to let somebody do it who knows how to do it. Otherwise next question would be "How to fix broken traces?"
                  Anyway, you need a hot air station (NOT hot air gun), raspberry pi with flashrom installed and a soic8 or wson8 adapter.
                  • cellular
                    • Apr 2020
                    • 21
                    • tr
                    #429
                    great work thank you very much... regards..
                    • Mugatu
                      • Sep 2020
                      • 7
                      • Sweden
                      #430
                      All Elitebooks, Probooks and zbooks which are up to ninth generation which should be up to year 2018, like 840 G5, are supported.
                      Do you know if the Probook 645 G4 (AMD Ryzen Pro 2000U series) falls into that same category?
                      All I know is that it started selling in June 2018, and I'm guessing these are the chips.
                      • xeniachile
                        • Sep 2020
                        • 5
                        • chile
                        #431
                        I have a hp G4 2072la, will BIOS F.2A Rev. A work to unlock my BIOS?
                        • mastsrl
                          • Apr 2019
                          • 38
                          • Argentina
                          #432
                          Worked like a charm on a HP Probook 4520s
                          it had bios setup password, desoldered flash, dumped bios, removed passwrod, reprogram, win!. After this i could finally update the BIOS(as it was super outdated).
                          Testing with a different bios dump yielded no boot
                          • danito
                            • Jun 2016
                            • 1003
                            #433
                            can someone help me with a dump for folio 1040 g2?
                            Thx
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              #434
                              No, pavilions are not supported.
                              • RethoricalCheese
                                • Mar 2013
                                • 1519
                                • Estonia
                                #435
                                I am really not sure. Too new for me so I have not tested it on that model yet.
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  #436
                                  do hp unlocker tool needed/must req for hp bios GD25b64CS1G chip or no need for this bios chip
                                  • versantejol
                                    • Sep 2020
                                    • philippines
                                    #437
                                    good day co tech i need smc bin file for hp probook 640 g1 thank you i hope i get the files..
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      #438
                                      No!
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1519
                                        • Estonia
                                        #439
                                        Well, you need to specify which model you have. BIOS chip models don't say much.
                                        • menshawy
                                          • Aug 2013
                                          • 400
                                          • egypt
                                          #440
                                          tested with hp EliteBook 850 G1 ok
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
