HP BIOS unlock tool
  • peste
    • 13357
    • ROMANIA
    #381
    Re: HP BIOS unlock tool
    Originally posted by ranlyranly
    Not able to open the unlocker. Keep getting an error.
    try..
    • dewako
      • Sep 2019
      • uae
      #382
      My laptops have two password administrator and power on password i removed administrator password but power on password still there please help..
      • N0f3ar
        • Oct 2016
        • 51
        #383
        hi i have 840 g5 can somebody help unlocking
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          #384
          Because it is not supposed to be opened. Read first post.
          • peste
            • 13357
            • ROMANIA
            #385
            make a copy on both chips and try this.
            • N0f3ar
              • Oct 2016
              • 51
              #386
              i did not find second one
              • N0f3ar
                • Oct 2016
                • 51
                #387
                found it on the back of the mainboard
                i will try now
                • N0f3ar
                  • Oct 2016
                  • 51
                  #388
                  Only orange led for the charger
                  I have tried both bios back to origina state, the laptop also did not power on only full speed fan
                  No display
                  • satoichiro
                    • Aug 2020
                    • Japan
                    #389
                    • peste
                      • 13357
                      • ROMANIA
                      #390
                      Originally posted by satoichiro
                      it's ok..what problem do you have ??
                      • youremydawn
                        • Feb 2020
                        • Vietnam
                        #391
                        Work perfect with 850G2 touch.
                        Thank you all!
                        • Am0rPHiA
                          • Nov 2011
                          • 31
                          • Greece
                          #392
                          On HP 840 g6 bios password was removed but admin password is still intact
                          so i can not access bios , any ideas?
                          thanks in advance
                          • peste
                            • 13357
                            • ROMANIA
                            #393
                            thanks in advance
                            post both original bios
                            • majubzer
                              • Sep 2020
                              Hello, I tried the tool for an HP 470 G5. I flashed with a CH341A into the chip (25B127DSIG I find no datasheet about it), but the Power-on Authentication still appears on log in.
                              Could you give a look to my original bios bin?
                              Thanks in advance
                              • Am0rPHiA
                                • Nov 2011
                                • 31
                                • Greece
                                #395
                                here are the bioses
                                i did not remove the power on password, someone else did , i tried to remove the bios admin pass unsuccessfully
                                • peste
                                  • 13357
                                  • ROMANIA
                                  #396
                                  here are the bioses
                                  look on the motherboard .. do you still have a bios chip ?? post that bios too..see on the other side of the board ..
                                  • majubzer
                                    • Sep 2020
                                    Originally posted by RethoricalCheese
                                    AA55 must stay as it is. And zeroing is not exactly the right word. You need to copy clean UserCred section with the same length from another file. There are other values in that section which have to be present for it to work. That's the main reason I did not want to clear up to AA55 automatically.
                                    Hello again, I read through this thread and came up with all of your comments. You are right, this section also needs to be replaced from a Non-locked bios to remove the Power-On Authentication. For my bios dump I did the following:
                                    1. Use the HPUnlocker_v1 tool to create an unlocked .bin.
                                    2. Open this unlocked bin file with HxD Editor.
                                    3. Search (Ctrl+F) for the keyword "UserCred" as Unicode. Note: In my case this appeared three times, but only one of them is the section needed.
                                    4. Select from the beginning (Starting in 55 00 73 00 65 00 72 00) until the flag "AA 55" appeared. This was of length "DE6" (hex) or 3558 (dec).
                                    5a. Open the empty file provided by peste and select/copy exactly the same section as in the previous step.
                                    try..
                                    5b. To make it easier for anyone, I attached the template as "empty-user-power-on-template.bin", so you only need to copy it directly, instead of doing step 5a.
                                    6. Paste write (Ctrl+B) the template into the selected section from step 4.
                                    7. Double check that the file has the same size as before replacing the template. (Ctrl+A), in my case the length was 1000000 hex.
                                    8. Save it as a new bin file.
                                    9. Flash this file into your chip. (I used flashrom in Linux, I can really recommend it)
                                    10. On booting i found a "Post Error" saying the memory size is different from last time, i pressed enter. Now there is no password on boot nor on bios!
                                    11. Just to make sure, go to bios > security and reset the security to default.
                                    I hope that is helpful for someone in the future. If more people can confirm this method it could be possible to automate this process inside the HPUnlocker tool, right?
                                    Thanks to RethoricalCheese for his tool and to all the guys posting here!
                                    • Am0rPHiA
                                      • Nov 2011
                                      • 31
                                      • Greece
                                      #398
                                      the bioses i posted were taken from the chip which i desoldered, the first one is the "untouched" and the second one is the unlocked which was created from the unlock tool. What to check on the other side? there is only one bios chip 25q256jev
                                      • peste
                                        • 13357
                                        • ROMANIA
                                        #399
                                        we ask you if there is another bios chip on the motherboard, apart from the 33MB one, it is usually on the other side of the motherboard compared to the 33 mb one and it has 16mb..if you don't have another chip try this. ..if the password does not disappear, then the password is in the I / O chip ..
                                        • Am0rPHiA
                                          • Nov 2011
                                          • 31
                                          • Greece
                                          #400
                                          unfortunately it didnt work, still asks for admin password when trying to access bios
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
