HP BIOS unlock tool
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #301
    Re: HP BIOS unlock tool
    Files look fine to me. Try writing again.
    • Ap78
      • May 2020
      • 15
      • Italia
      #302
      Originally posted by HobbyElectronicDude
      1. Attempt to read out the Winbond W25Q128FVSQ-1442 on the board using a clip and CH341a (black) -> all attempts have failed
      5. Powered the laptop and... BLACK -> Fans Spin, Keyboard and Led's light up but no startup to OS or BIOS
      With the MEAnalizer, a CMD window pops up briefly and then closes again.
      Hi, I'm not so expert, only my first experience, anyway:
      1. - - > did you try to Use clip with power supply connected? I had failure at first as well before doing in this way.
      5.- - >could be not resoldered correctly? I don't really know, but try to connect power supply and after the clip on the chip (disconnected from usb PC) and check if the 5V LED on the miniprogrammer is lighting, if yes it means good connection with the chip, so it could mean the chip with the mb is soldered well.
      MEAnalyzer: you need drop the file in the CMD window and enter... If the bin file is correct you should see some info in a table, if not some "invalidi.." message
      • HobbyElectronicDude
        • May 2020
        • 6
        • Switzerland
        #303
        A beautiful good morning,
        Thanks for the answers, here is another confirmed unlock from an EliteBook 850 G1, YAY!
        I don't know what went wrong on the last try. I removed the chip from the board again and read it out. The dump had many differences across the entire memory. So I deleted it again, flashed it, verified it with "ch341 Programmer" and "AsProgrammer" -> Both passed. Soldered in, power on and it boots.
        Many thanks to everyone involved for this interesting thread and especially for the "Unlocktool", great work!
        Best regards
        Ruedi
          • May 2020
          • 6
          • Switzerland
          #304
          Yes, I tested all the options I found. With and without battery, with and without power supply, with and without CMOS battery, with and without RAM, mixed, different software ... I never got a reading, not even a clean detection of the chip.
          I was able to solve this Problem too. Sometimes it makes sense to read the readme, after all, someone has bothered to explain how the program works and what the requirements are.
          • rupupuni
            • Mar 2020
            Originally posted by tlfrance
            I've successfull removed bios pwd on my 840 G3 with your utility and CH341A programmer. I've soldered 8 wires around bios chip and did the job
            How difficult was this? I have an 840 G3 that needs the password removed too.
              • May 2020
              • 6
              • Switzerland
              #306
              That depends on your soldering skills. But due to the fact that you're asking, you'd better get someone to help you.
              • Ap78
                • May 2020
                • 15
                • Italia
                #307
                Due to my poor soldering skills, I used a clip soic.
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #308
                  840 G3 has wson8 chip so clip can't be used here.
                  • shd
                    • Jun 2020
                    #309
                    @RethoricalCheese thank you for HPUnlocker_v1 and all your efforts !!!
                    This worked for an HP 850 G1 . ( with the bios chip desoldered, did not work to dump it in circuit )
                    Bios version -L71 Ver. 01.44
                    I've just drag and dropped the rom dump file( of the password locked bios) over the HPUnlocker_v1 icon and got the unlocked file version in the same directory.
                    Also, for whom does not have memory flashing/reading tool, they can use a raspberry and follow the method stated https://forums.mydigitallife.net/thr...il-test.56701/ .
                    If you don't have the necessary zif socket for the chip, as a last resort, you can try using logic analyzer probes as seen in the attach picture, but make super sure probes are not touching. I don't take any responsibility if you destroy your electronics. Its just an last resort ideea, on your own risk.
                    • quidep
                      • Apr 2020
                      • 19
                      Hello all,
                      I'm back and try to remove the BIOS password from my EliteBook 840 G2. Here is a short summary of my previous activities:
                      - I tried first to read out the BIOS chip using a clip, no success
                      - I desoldered the chip from the mainboard and tried to read the content using different tools with a CH341A programmer and using flashrom with a Raspberry Pi 4. I've never got the same content, there where always differences, in the area between 00EB6000 and 00EB6FF0
                      - I've been adviced to buy a new chip and to flash this file: https://www.badcaps.net/forum/showpo...&postcount=199
                      - I bought a new BIOS chip, was able to flash the mentioned file and to verify it. First soldered it back using wires, then again directly onto the mainboard. The laptop didn't boot at all. The LEDs of the caps lock and num lk buttons blinked, the backlight went on and then the laptop turned off.
                      Do you have any idea, what I could try else?
                      • quidep
                        • Apr 2020
                        • 19
                        The blink code says "BIOS corrupt". I tried to do a BIOS recovery using an USB drive as described here https://support.hp.com/us-en/document/c02693833, no chance
                        • quidep
                          • Apr 2020
                          • 19
                          Aren't there any suggestions? Is the mainboard finally bricked or is there any possibility to recover?
                            • May 2020
                            • 6
                            • Switzerland
                            #313
                            In your place I would flash the two previous dumps (CH341A and Flashrom) onto the new chip. Just to see if it works. If not, solder the original chip again, provided that the original BIOS is still on it. If you succeed with any of these options, you know where to start.
                            • D'Bryte
                              • Dec 2018
                              • 32
                              • Africa
                              #314
                              Thank you...just unlocked ProBook 430 G5
                              • sourcebf
                                • Jul 2016
                                • 433
                                • N/A
                                #315
                                works for me like a charm thanks a lot
                                • acshud
                                  • Sep 2017
                                  • 106
                                  • romania
                                  #316
                                  works on 840 g3.thank you
                                  • rashmignanesh
                                    • Jun 2020
                                    • 14
                                    • US
                                    #317
                                    hi
                                    i download but not execut (Fatal error detected) - Failed to execute script HPUnlocker
                                    pls guide me proper solution
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      #318
                                      Did you read how to use it?
                                      • rashmignanesh
                                        • Jun 2020
                                        • 14
                                        • US
                                        #319
                                        No pls guide me
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #320
                                          First post says to drag and drop your *.bin file on exe file.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
