HP BIOS unlock tool
  • parag.thakkar.27@gmail.co
    • May 2020
    • 12
    • India
    #241
    Re: HP BIOS unlock tool
    Hi...this is working...but in the beginning it shows "system is booting in manufacturing program mode 32" ... I am not sure what this is but apart from this it is working fine...
      • May 2020
      • 12
      • India
      #242
      one issue is there... I am never able to shut down the laptop... instead of shutting down it restarts...
      • peste
        • 12226
        • ROMANIA
        #243
        try this one too, but remove the bios chip from the motherboard before writing, the DMI information must be entered after writing.
        https://www.youtube.com/watch?v=rP3A3HWM_-Q
          • May 2020
          • 12
          • India
          #244
          I have taken out wires from the chip.. can I do that without taking out the chip?
          • peste
            • 12226
            • ROMANIA
            #245
            I have taken out
            if you do not remove the chip from the motherboard when reading or writing the bios chip you may have errors.
            do not use the clip you will have errors ..
              • May 2020
              • 12
              • India
              #246
              I am not using a clip.. instead I have soldered the wires on the chip legs to 8 pin base which i have inserted in the programmer...I use this programmer for burning firmware in mcu...
              • pipo7169
                • May 2016
                • 27
                • usa
                #247
                should use it in both main and EC dump or only main one
                • reessi
                  • Jan 2016
                  • 323
                  • uk
                  #248
                  Hi there, I could not get it to work on a HP Elitebook 745 G3. I dumped chip contents and used the unlocker to generate the unlocked file and wrote it back. Laptop still had the password so I used total commander to see what was changed and it appears to just be the already blank area at the beginning?
                  See attached pic if you could advise what I have done wrong please. I also attach the .bin files (rename from .zip, they are not zips.)
                  Many thanks.
                  • reessi
                    • Jan 2016
                    • 323
                    • uk
                    #249
                    Also how is the tool clearing the correct part, can I just do it myself in a hex editor?
                    • RethoricalCheese
                      • Mar 2013
                      • 1514
                      • Estonia
                      #250
                      Seeing that you have an empty beginning and it modified the beginning, your dump was faulty. Did you verify when reading?
                        • 20279
                        Many thanks.
                        Will you please post proper zipped files next time. The total file size for both bin files zipped is 6.34 MB
                        • reessi
                          • Jan 2016
                          • 323
                          • uk
                          #252
                          I un-soldered the chip with the hot air station, I took 2 copys from the chip, verified both with total commander as advised in this thread and wrote back the unlocked one and verified. The laptop posts fine with the unlocked version. Sorry for not zipping I thought it was a problem with the forum not letting me attach the file. Have I copied the correct chip U366 next to the bios battery. There is another at the other end of the board, U365. How can we know normally without a Schematic? See Pics. I could try the other one but I don't want to take un-neccessary risks unless I'm certain it is. The bios battery and its socket were already ripped off when I opened this laptop as well as the ram slot.
                          Many thanks.
                          • reessi
                            • Jan 2016
                            • 323
                            • uk
                            #253
                            I am going to try the other chip with is bigger 16mb, the one I did is 8mb. I will report back.
                            • RethoricalCheese
                              • Mar 2013
                              • 1514
                              • Estonia
                              #254
                              If you don't want to take unnecessary risks, just ask before doing anything you are not sure of. It is always the bigger chip on HPs. So your first attempt was pointless.
                              • reessi
                                • Jan 2016
                                • 323
                                • uk
                                #255
                                Hurray, it worked, thanks to everyone and next time I won't jump to conclusions. What does the other chip do? Do you think I need to get it back off and write the original dump back. The changes are just in the blank section at the beginning as pictured above!
                                Cheers
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1514
                                  • Estonia
                                  #256
                                  Probably wouldnt make any difference.
                                  But I personally would put back original content, would only take a minute of my time.
                                  • reessi
                                    • Jan 2016
                                    • 323
                                    • uk
                                    #257
                                    Yeah I did that, but what is that chip for? Also I've been un-soldering them everytime. Can they be done in situ? I was afraid of the dumps being wrong and would be game over if I flashed back a bad copy!
                                    • Mechanicalbytes
                                      • Apr 2020
                                      • 26
                                      #258
                                      After trying Mazzif's bios tool a long time a go, I thought the newer HP's were unlockable.
                                      HP 840 G3 Admin P/W removed
                                      Big thanks to RethoricalChesse for a fantastic tool.
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1514
                                        • Estonia
                                        #259
                                        They contain Intel microcode and some other stuff. Also a copy of DMI data.
                                        You can solder wires to gold pads but if you have a hot air station, desoldering using that is always faster.
                                        I have tried pogo-pins once but it didn't work then. Will try again some day.
                                        • slaine
                                          • Feb 2020
                                          • 21
                                          • germany
                                          #260
                                          Hello Everyone,
                                          got a 15G6 - what a beast in today - sadly BIOS-PWd. Had no Luck with manual removing it nor with the unlocker tool. Maybe someone want to have a look at it and can help me out.
                                          I found the usercred in the typical location but at reboot it seems to restore the settings. Intel ME is @ Version 12.0.45.1509 PMC is @ 300.2.11.1020 - maybe the put in an anti tamper protection?
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
                                          • iZakre
                                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                            by iZakre
                                            Hello everybody!
                                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                            The thing is that I had installed TeamViewer and could log into the computer...
                                            02-19-2023, 02:27 PM
