HP BIOS unlock tool
Last edited by peste; 04-13-2020, 02:27 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs. -
Every donation made will go towards server fees and maintenance costs.Comment
Re: HP BIOS unlock tool
Is it only a dmi problem,or something else has been wiped?if you fill ihe dmi data in your uploaded EC,in the original EC dump it starts at line 5000(using HxD).If you have seen the message in previous models"restoring data from network cotroller" or something like this.It was restored from EC.I am not sure but just to test.Comment
Hei. I have HP 850 G1 which i can not unlock via hp HPUnlocker_v1
I dump both chips (i do not have clue which one is responsible for password)
Executed by HPUnlocker_v1, erase both of them and reflash.
Does not work, can anyone remove password for me?
https://1drv.ms/u/s!AqPFcaDMKFJ_gphn...UHVcg?e=s8HPKiComment
Firstly.. Do not randomly do things like that. If you do not know what to do, ask.
You only need to read, modify and write the larger chip. For example named W25Q128FV or something similar with 128 in the name.
Secondly.. Your read is very faulty. Did you not verify what you read?
Does your laptop even boot anymore?Comment
Hi... can someone post the unlocker tool again.... the which is there says the archive is damaged... I have a HP probook 440 G4... can this tool help in this model?Comment
Hi.. I downloaded the binary file...However the tool gave me some python error when I dragged the binary on the tool... Can you please provide me with the unlocked binary... I am attaching the downloaded binary... my laptop is hp probook 440 g4...Attached FilesComment
HI... I read the instructions but still could not make it work... I copied the exe and the binary file in the d drive (no folders involved)... I dragged the binary file on top of the tool... The tool gives the error...Comment
post the bios hereDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
hi...please find attached the bios...Attached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by KesavanHello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
Attached my backup file
SERIAL NO: 5CG4300CNT...-
- Loading...
