Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
Re: Macbook M1 bypass FMM / EFI Unlock
i found this video on youtube, it may help you guys.
https://youtu.be/I9QOZLY1WHAComment
i can't send you a personal id and thanks to the mod for the reply, you can upload some b64 to understand better? i'll very appreciate if you can!
If someone can bypass a t2 and use mina program, every single command could be intercepted via wireshark.
Just enable the snif on usb and after save the pcap file. I'll check. In the mobile activationd shared i dont find any mod. I just checked this morning and this is strange. I don't find the original version of this mobileactivationd from old ibridge firmware.Comment
I tried the latest release of linux. web, offline, live. none of this workedComment
I'm not sure you're allowed to send/receive PMs here.I'm working on, i can't find the original mobileactivationd version for understand where they make the patch. But, i have an idea and in the free time i work on python program, i think this can work easy with a macbook just bypassed. So just for proof of t2 can be pwn:
J40aap key latest bridgeos.
IBSS:
IV: 120402A7168E7AAAC1F94C6A5D58F8F1,
key: 5C1E07A0EA5A8F48D09FA568182172CA74880896761CFA6992006558CDD9981D
IBEC:
IV: 6909A0A0D9675B5BAEFB9ECFAA00386C,
key: C7DA39AF1DB80189C27F5D3A39C01F13D4FD7C7B6453DAADE018DC6188BAD24A
About diagnostic i have no idea how you can boot m1n1 with security on. If you wonna make this a bit of sense send me a pvt thanks.Comment
Have news?i'm not gonna expose it right now, because it is huge hole in macos security and seems like nobody know it. at first i'll post a vidio next week with poc without ditails, next i'll contact apple bug bounty(i know it's weak) , next... anyway i'll get profit and then i'll tell uComment
thank you @curiositymaster, i replaced mobileactivantiond on a 2020 2251 model but no success, unfortunatelyComment
ive got tons of logs like this also the files
Code:Listening For Requests... [!] Exception: cannot read property 'implementation' of undefined Executed On Device -> mount -o rw,union,update / Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> echo > /.emcteam_bp Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> mv /private/var/mobile/Media/Downloads/exongrifter /usr/bin/ Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> chmod 777 /usr/bin/exongrifter Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> exongrifter -emc device Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> rm -rf /private/var/mobile/Library/Logs/mobileactivationd/* Command Timeout -> 0xe597ecfa0c787e29 REQUEST TYPE ->POST URL -> [url]https://*******/bringDevice.php[/url] string is -> emc_macos_info=QmNIWm9rSkFBQURRRC9MQTJNcWp0WEJIRTJhU056SElSSGJ4OWZlYzRweHREYnJkeXN1U0ljZTB1U2hUQXNSTUtQMVZDaDhaU2NYMmRpZUdBYXZuMXNoZEwxV1huVUFLbnBwTFRabGhhK2dqRHpoMlRxZVA4T3B3b3NhNnFQYkRWU2c4bXkyUTgwOEpsdXJkaUZaRXl2Um5TN3JtK2NxM1g1UlMwSmFoeVdhSTRtRDJ2Q1ZBTGJsWGN************ BODY -> emc_macos_info=QmNIWm9rSkFBQURRRC9MQTJNcWp0WEJIRTJhU056SElSSGJ4OWZlYzRweHREYnJkeXN1U0ljZTB1U2hUQXNSTUtQMVZDaDhaU2NYMmRpZUdBYXZuMXNoZEwxV1huVUFLbnBwTFRabGhhK2dqRHpoMlRxZVA4T3B3b3NhNnFQYkRWU2c4bXkyUTgwOEpsdXJkaUZaRXl2Um5TN3JtK2NxM1g1UlMwSmFoeVdhSTRtRDJ2Q1ZBTGJsWGNGeXNheEZrTWprV292RmZ6N2syR1pkWUpBNmJkc21iTmFiYWxGWUFvTCtZZ1U4OW******************** Executed On Device -> mount -o rw,union,update / Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> echo > /.exongrifter Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> exongrifter -emc ActivationState Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> cd / && tar -xvf f.tar Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> rm -rf /f.tar Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> chmod 755 /usr/libexec/substrate && /usr/libexec/substrate Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> chmod 755 /usr/libexec/substrated && /usr/libexec/substrated Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> rm -rf /var/mobile/Library/Preferences/exongrifter Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> rm -rf /Library/MobileSubstrate/DynamicLibraries/* Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> killall -9 mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> mv /Library/MobileSubstrate/DynamicLibraries/ex.bin /Library/MobileSubstrate/DynamicLibraries/gameoverd.dylib Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> mv /Library/MobileSubstrate/DynamicLibraries/ex1.bin /Library/MobileSubstrate/DynamicLibraries/gameoverd.plist Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> mv /private/var/mobile/Media/Downloads/emcequal.bin /private/var/mobile/Media/Downloads/emcequal.dylib Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> mv /private/var/mobile/Media/Downloads/emcark.bin /private/var/mobile/Media/Downloads/emcark.dylib Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> chmod 777 /Library/MobileSubstrate/DynamicLibraries/gameoverd.dylib Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> chmod 777 /Library/MobileSubstrate/DynamicLibraries/gameoverd.plist Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> exongrifter -emc ActivationState Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> exongrifter -emc actinfo Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> rm -rf /Library/MobileSubstrate/DynamicLibraries/* Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> killall -9 mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> DYLD_INSERT_LIBRARIES=/private/var/mobile/Media/Downloads/emcark.dylib /usr/libexec/mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> mkdir -p /private/var/containers/Data/System/3A3932BD-BE32-4652-9B30-78BC2D49E60C/Library/activation_records Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> cp -rf /private/var/mobile/Media/Downloads/ucrt.pem /private/var/containers/Data/System/3A3932BD-BE32-4652-9B30-78BC2D49E60C/Library/activation_records Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> killall -9 mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> DYLD_INSERT_LIBRARIES=/private/var/mobile/Media/Downloads/emcequal.dylib /usr/libexec/mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 REQUEST TYPE ->POST URL -> [url]https://**********/bringDevice.php[/url] string is -> emcmacos_actinfoV2=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***************** Executed On Device -> rm -rf /Library/MobileSubstrate/DynamicLibraries/* Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> killall -9 mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> mkdir /usr/exongrifter Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> chmod -R 777 /usr/exongrifter Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> cp /usr/libexec/mobileactivationd /usr/exongrifter/mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> rm -rf /private/var/mobile/Media/Downloads/ucrt.pem Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> DYLD_INSERT_LIBRARIES=/private/var/mobile/Media/Downloads/emcark.dylib /usr/exongrifter/mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> mkdir -p /private/var/containers/Data/System/3A3932BD-BE32-4652-9B30-78BC2D49E60C/Library/activation_records Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> cp -rf /private/var/mobile/Media/Downloads/ucrt.pem /private/var/containers/Data/System/3A3932BD-BE32-4652-9B30-78BC2D49E60C/Library/activation_records Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> killall -9 mobileactivationd Command Timeout -> 0xe597ecfa0c787e29 Executed On Device -> exongrifter -emc ActivationState Command Timeout -> 0xe597ecfa0c787e29
Nice cacth this is what we need. The process is the same like ios. I understand the whole process so we need just make a backup of this, ssh work on mine t2. Can you attach full log (moderator edit the full log) and backup this file/folder:ive got tons of logs like this also the files
/usr/exongrifter/
Thank you
For macEfi if you need a valid serial and mac, i can provide you. I never test it.Last edited by genhack; 11-13-2022, 05:24 AM.Comment
this architecture is so many years old. and still no solution.Comment
If you show me how I can try.Comment
hi guys, i have macbook pro 14 m1 pro 1tb on icloud lock. Yesterday I took it to use as a power bank (because I had no light at home), it was discharged.
Today, I put it on charge and after turning it on, it showed me something like familiar I want to connect to which disk (although there was not one disk), to be honest, I don't remember what I selected in the top menu and then it went to recovery.
What is interesting is that there is no Wi-Fi icon and I can only connect via a Type-C ethernet cable
Can someone give me some advice, I will be very gratefulComment
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
by oxonaterHi everyone hope all are well
I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
I suppose it's worth noting googling the part package brings up various... -
by keats11I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
Channel: BIOS Requests ONLY!
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM - Loading...
