x513ea r5.3
    • 22170
    Originally posted by albologna
    Yes, sorry
    Asus service bios + your DMI . .If it doesn`t work its not a bios problem.
    • albologna
      • May 2022
      • 32
      • italy
      #62
      Thank You. Tested and it is NOT working. It is the same. I think the Gpu is done even though the the vdd resistence is 3 ohm. I will check the led lines on the monitor, maybe the fault is there
      I think I found the problem. It has 4 ohm on ram 1.2V power supply. Found that one of 4 slot on voltage injection was consuming 1,2A. Removed that slot and the short was gone. Still the pc is not working. Can someone help on disable the ram Onboard?
    • narpa
      • Aug 2017
      • 11
      • France
      #63
      Hello, i hope to be in the right place for my bios issue : (Black screen, chip is unreadable, can't do backup, I tried several times, chip unsoldered. chip model Gigadevice 25B128E)
      Asus X513EA Rev 5.3
      Here is the information in text and image too
      Serial number And QRcode fan side
      SN 24M : MAN0CV10T95541A
      MFD : 2021.10
      MODEL : X513EA
      Main Board Serial and révision : X513EA MAIN BOARD Rev 5.3
      I hope you have enough information to create a .bin of the right size for me. Thank you
        • 22170
        Asus X513EA Rev 5.3
        MFD : 2021.10
        MODEL : X513EA
        Post moved to X513EA Rev 5.3​ thread. Attach pictures to your post as an attachment. What model is your programmer and software version, and is the chip in the support list
        • narpa
          • Aug 2017
          • 11
          • France
          #65
          sorry, here are the attached picture and my programmer is a revelprog-is, software is updated to version 1.9.1... i'm searching for supported chip, i used a 25Q128 to test other bios, i can program and read 25Q128 without problem
          the GD25B128 chip is in supported list
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            #66
            Asus X513EA Rev 5.3
            MFD : 2021.10
            MODEL : X513EA
            try this bin rebuilded and fresh bin
            • narpa
              • Aug 2017
              • 11
              • France
              #67
              thank you kalilinux25​ i will try as soon as possible
              • narpa
                • Aug 2017
                • 11
                • France
                #68
                i tried this morning but nothing more, same thing, when i connect the power, white led on power button and still black screen, fan not spinning, cpu is hot (60°). Must be a cpu or gpu issue. Thank you for your help again !!! I made a paypal donation to support your work.
                • kalilinux25
                  • Mar 2018
                  • 2093
                  • ZAMBOANGA SIBUGAY
                  #69
                  thank you
                  • shamanizator
                    • Apr 2021
                    • Poland
                    #70
                    Please, can you fix BIOS?
                    Problem with the RAM
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12423
                      #71
                      Serial number ?
                      • sourcebf
                        • Jul 2016
                        • 433
                        • N/A
                        #72
                        hi for all,
                        I have an ASUS X513AE R4.3 that powers on and consumes 0.33 amps. All voltages are present except for +VCCIN (see attached picture). I checked the BIOS dump and found that the KBC is IT8985, but the board has IT5125, so this dump is not the original. I have attached this dump. I hope someone can help me with a working dump for this board or provide any advice.
                        • peste
                          peste commented
                          Editing a comment
                          merged post..
                      • sourcebf
                        • Jul 2016
                        • 433
                        • N/A
                        #73
                        Originally posted by sourcebf
                        hi for all,
                        I looked for it but couldn’t find anything I could start working on, so any help is appreciate
                        • cuongphampq1993
                          • Nov 2020
                          • 5
                          • florida
                          #74
                          help me unpass bios
                          • cuongphampq1993
                            • Nov 2020
                            • 5
                            • florida
                            #75
                            unpass bios, help me
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12423
                              #76
                              Serial number . Don't forget.
                              • s_l_c
                                • Nov 2024
                                • Poland
                                #77
                                X513EAN doesn't turn on, black screen. Battery light flashes white 2 times, several times and then shuts down. I found a BIOS update file in ESP, so I assume this may be a failed BIOS update by windows.
                                I have attached bios dump.
                                Serial Number: N2N0CV12369708B
                                Thanks for help in advance.
                                  • 22170
                                  Try this bios.
                                  • s_l_c
                                    • Nov 2024
                                    • Poland
                                    #79
                                    Originally posted by SMDFlea
                                    Try this bios.
                                    It worked! Thank you very much!
                                      SMDFlea commented
                                      Editing a comment
                                      You`re welcome :-)
                                  • ariffine
                                    • Aug 2023
                                    • indonesia
                                    #80
                                    X513EAN doesn't turn on, black screen, can anyone help repair this bios Original
                                    • mikeybass
                                      by mikeybass
                                      04-23-2025, 04:30 PM
                                    • akwky
                                      by akwky
                                      Hi!
                                      04-14-2025, 01:56 PM
                                    • al3m0di
                                      Update bios EFCN58WW to EFCN59WW
                                      by al3m0di
                                      Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                                      I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                                      The BIOS version is EFCN58WW.
                                      When I turn on the device, it displays the message:
                                      "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                                      The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                                      I've tried
                                      07-29-2024, 10:32 AM
                                    • capoplays
                                      Help with BIOS update on Dell G15 5515 after chip replacement
                                      by capoplays
                                      Hey everyone,
                                      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                      When I check the BIOS using the F12 menu Flash...
                                      10-24-2025, 06:53 AM
                                    • 0xx
                                      2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                      by 0xx
                                      Hi folks,
                                      My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                      What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                      I assumed that Windows Update was interrupted due to closing...
                                      09-14-2025, 03:46 PM
