bios x512dk
  • Bios Cracker
    • Oct 2024
    • 323
    • India
    #41
    Originally posted by dahm
    Still having the same issue with the CPU not overheating
    It is ASUS website downloaded file...you need to further check hardware.
    • boneco69
      • Jul 2010
      • 7
      #42
      Please, could someone explain how to edit the UEFI/BIOS image? I wll go read the BIOS guides and resources but i see too many posts asking to fix theyr bios and then they need to post serial number sticker.
      I have an Asus X512DK that i think is bootlooping after the bios itself can show something. If i connect the power charger the system goes right away to powerup all voltages (all seem ok) and the CPU is heating a lot (executing the bios code i think) and the LCD screen is power-cycling (darkens). By the symtoms i think this is a BIOS corruption.
      Best regards.
        SMDFlea commented
        Editing a comment
        If you post your current backup, laptop serial number (it must be typed) and a picture of the long white barcode sticker on the motherboard then someone will help.
    • dahm
      • Apr 2018
      • 35
      • alger
      #43
      Thank you very much I will try
      • boneco69
        • Jul 2010
        • 7
        #44
        Escuse me because of delay (work in school and the time flyes away... by the way this is from a student laptop that i am trying to help).
        So the sticker and the original BIOS dump is attached.
        In the previous post i tought that the model was DK and then scanning the QRCode (attached) i saw that this is in fact DA model. I was wrong because of the thermal design : there are two metal plaques screewed at the mainboard - one for CPU and one for, apparent, GPU. Now i see closely that this board uses integrated GPU in CPU package. Sorry for that misinformation.
        S/N: K3N0CV10R13613B
        Best regards.
        • peste
          • Dec 2016
          • 13728
          • ROMANIA
          #45
          Best regards.
          try post #28...
          https://www.badcaps.net/forum/troubl...2d#post3626972
          • rui4892
            • Mar 2017
            • 57
            • Portugal
            #46
            please correct dump...with attached dump no picture and cpu gets hot, tested other dumps but no detect nvme. thanks
            • peste
              • Dec 2016
              • 13728
              • ROMANIA
              #47
              post S/N, full name and model, motherboard model, etc.
              • rui4892
                • Mar 2017
                • 57
                • Portugal
                #48
                sn KCN0CV04Y132504, board X512DK rev 2.1, model F512D
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12406
                  #49
                  X512DA
                  • rui4892
                    • Mar 2017
                    • 57
                    • Portugal
                    #50
                    Originally posted by hoaca388
                    X512DA
                    thanks but not detect nvme
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12406
                      #51
                      Check hardware again, here is the new bios file from ASUS Homepage.
                      • rui4892
                        • Mar 2017
                        • 57
                        • Portugal
                        #52
                        You were right, hardware problem, on the board, the primary power supply +12vsus was missing, caused by a failure of the BAT54SDW component in position PD8701, resolved by replacing it. Thank you
                        • benny2020
                          • Jun 2025
                          • 4
                          • India
                          #53
                          post the contents of the bios chip even if it is corrupted..
                          The bios chip must be unsoldered from the board before writing or reading..
                          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                          solder wires between the programmer and the bios chip..
                          you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                          Hi
                          SN : K8N0CV04990032F
                          Model Asus Vivobook X512DA
                          I attached old bios check it and help me to fix
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12406
                            #54
                            Originally posted by benny2020
                            Hi
                            X512DA
                            • benny2020
                              • Jun 2025
                              • 4
                              • India
                              #55
                              X512DA
                              Thanks, bro, for looking into it during your valuable time.
                              But this BIOS isn't working—no boot, no lights, nothing.
                              • mkdj
                                by mkdj
                                Dear all,
                                10-19-2025, 04:41 AM
                              • razor_amd
                                by razor_amd
                                12-15-2020, 07:07 PM
                              • pirati
                                by pirati
                                10-27-2025, 04:20 PM
                              • DynaxSC
                                by DynaxSC
                                06-14-2024, 03:49 PM
                              • Ahari
                                by Ahari
                                I...
                                08-13-2025, 06:12 AM
