Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by rex98 View Post
    here flash both.
    Thanks for the help but it doesn't work, everything is perfectly soldered, and with this dump it doesn't even try to make the loop. 😞
      anh đó giúp tôi về vấn đề này ạ trân trọng cảm ơn
      Can you help me with this problem? Thank you very much.
      in English please..
        in English please..
        post the S/N, the full name and model of the laptop, etc.
          I'm sorry
            I'm sorry
            flash both
              flash both
              I checked it and it doesn't work.
                Send to you
                  Originally posted by minhdigital View Post
                  Send to you
                  it works but black screen help me
                    Pls I need file to remove endpoint security problem, I don't hv the serial number
                      HP Elitebook 840 G8 Endpoint Security Controller Problem
                      error endpoint security error plz help me
                        Missing serial number.
                        Become a Badcaps supporter
                        Thanks to all supporters.
                          sn: 5CG1353XPG
                            sn: 5CG1353XPG
                            endpoint security
                              thank you it works
                                Sir i need remove password or Patch
                                  Read the PM i sent you.
                                    PM what ? I have Lenovo Laptop X390 Yoga can you patch for me or have you Patcher exe
                                      This thread topic is for the HP 840 G8 ,did you look at the thread title
                                        Hi Sir, can you help me i have hp 840 g8 swat lock problem see attachment.. I already reprogram the bios chip beside cpu at first it was successful but the swat lock return after i re program it it keeps on retsarting i cannot even access bios due to constant restart... thank you in advance
                                        SN#5CG211439R
                                          SN#5CG211439R
                                          only flash this main at first boot reset security settings to defaults. its normal it would promt bios data identity recoverd,
