hi i need hp elitebook 840 g8 both bios files with clear me main bios and ec bios
Extract bios password from EliteBook 840 G8 Bios dump, possible?
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Hi , Need help with unlock my Hp elitebook 840 G8 bios pw
Hp Elite book 840 G8
Sn : 5CG1417XJT
Attached Files↵
https://www.badcaps.net/donateComment
Sn: 5CG1417XKB
Thx in AdvanceAttached FilesComment
Hello. I need bios+ec for an 840 g8 computer. There is 5v and 3.3v, but the fan starts and stops once. The image does not appear. Can you help?
Serial Number : 5CG2275NVW
Product Number : 687L7AV
Description : HP EliteBook 840 G8build id: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfuture byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfAfPgSguhKjhk8mEmwn7nVngpq.3B Attached FilesComment
Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
S\N 5CG2157WVT
flash only this EC 2nd chip. it will promt endpoint security controller just ignore it enter. it will disappear in next boot.
next time use any hex editor fill with ff in this offset 00037000 to 000379df
IF YOU HAVE MORE KNOWLEDGE ABOUT OTHER MODELS, I'M WILLING TO LEARN. 🤩🤩🤩🤩🤩🤩🤩🤩Comment
Buenas noches, me trajeron un HP Elitebook 840 G 8 que simplemente no se enciende, el bloqueo de mayúsculas parpadea, no sé si podría ayudarme a reparar el BIOS.
HP ELITEBOOK 840 G8
ID de producto 47F04UC#ABA
SN# 5CG1421MSYAttached FilesComment
Hello.
endpoint security gives error. Can you fix this
840 g8
6050a3217501-mb-a01Attached FilesComment
Try this, post 1, 5 https://www.badcaps.net/forum/troubl...security-errorComment
Good morning Gentlemen of great wisdom. I need your valuable help in the following case: I have an EliteBook 840 G8 computer that arrived with a password in the bios. The first mistake I make is not taking the backup of the 3 chips before starting to modify. I tried to remove the password by unlocking the EC and the device turned on once but still had the password. The Second time I tried to unlock the password both Main Bios and EC. From that moment the equipment tries to start in a loop without providing video. I have tried the bios backups that are on the Internet and the same thing, I am sure that there is no missing resistance nor is there any altered nearby component, I must also say that everything has been perfectly welded. As additional information, I must say that with my bios backups the computer does not beep for a ram memory error, but with a backup found on the internet it does beep for a ram error but it still continues in a loop without video.
HP EliteBook 840 G8, SN# 5CG1411K3R, Board CORVETTE-6050A3217501-MB-A01(A1) UMA HSN-I41C-4. The board is SRK1F (Core I7). I appreciate any help provided.
Additional addendum: I suspect that the bios of Core 5 and Core 7 SRK1F are different if they are on the same board.Attached FilesComment
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by AhariHi all,
I...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
Channel: BIOS Requests ONLY!
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
