Extract bios password from EliteBook 840 G8 Bios dump, possible?
    • 20984
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by hyditech
    thank you so so much... Password cleared.....Please can you guide me on how you did it...i will want to do it myself...Because i still have 3 more that i need to do and i dont want be asking much...
    but thank you i really appreciate...
    He explained how he did it,with a hex editor,maybe its time you learn how to use one,there`s plenty of guides. Also the "440 g8 unlock" script does exactly the same thing to the 32MB EC,so you either didn`t use it properly or you didn`t even try and just wanted someone else to do it for you,as usual.There`s only so much hand holding we can do.
    Quote of the day: "Failure is not a crime. The crime is not trying."
    • hyditech
      • 272
      • nigeria
      #522
      i am really sad because try really try it and i fail.. i dont know where i make mistake..i will have to picture it and send here so that you can correct me.. but i really appreciate
      • rex98
        • Feb 2023
        • 1280
        • Mandaue CEBU, Philippines
        #523
        try exploring the hex editor compare the files in your ec and the one that i sent that's unlocked. there you will see the difference and try to unlock DIY.
        you can't learn if you're afraid to try.
        • izaak94
          • Mar 2019
          • 129
          • mexico
          #524
          Hello, could you help me, my BIOS is blocked and absolute, but I already tried with other files from the forum but with audio problems or with Thunderbolt ports, with their original programming they work.
          HP EliteBook 840 G8
          S/N: 5CG212FBG0
          • hoaca388
            Badcaps
            • Jan 2022
            • 11798
            #525
            Originally posted by izaak94
            hello, could you help me, my bios is blocked and absolute, but i already tried with other files from the forum but with audio problems or with thunderbolt ports, with their original programming they work.
            Hp elitebook 840 g8
            s/n: 5cg212fbg0
            vvvv
            • izaak94
              • Mar 2019
              • 129
              • mexico
              #526
              Originally posted by hoaca388
              vvvv
              The same BIOS locked
              • lolgg
                • Jan 2021
                • United Kingdom
                #527
                I need help to unlock the bios dump for Hp Elitebook X360 840 G8. I tried HP Unlocker and RC Unlocker they not working because of the 32bit mb dump. please help. I have attached the both front main dump and rear ec dump.
                  • 20984
                  You must post the laptop serial number.
                  • izaak94
                    • Mar 2019
                    • 129
                    • mexico
                    #529
                    any solution i wrote the submitted file and it is still locked
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11798
                      #530
                      Again
                      • rex98
                        • Feb 2023
                        • 1280
                        #531
                        HP EliteBook 840 G8
                        S/N: 5CG212FBG0
                        Flash this both main and EC its password and absolute unlocked. at first boot be patient. after identity recovered go-to bios reset security to defaults.
                        give feedback please..
                        • izaak94
                          • Mar 2019
                          • 129
                          • mexico
                          #532
                          Thank you very much, this file worked perfectly, I appreciate your time.
                          • C-Badger
                            • Oct 2017
                            • 7
                            I've removed bios password via hpunlock. Problem is on boot I get the endpoint popup. Can somebody have a look please and thank you. Attached files from before unlock hopefully.
                            840 g8
                            5CG2482TT3
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11798
                              #534
                              840 g8
                              5CG2482TT3
                              VVVVVV
                              • C-Badger
                                • Oct 2017
                                • 7
                                VVVVVV
                                Thank you, it works.
                                • Hachem25
                                  • Aug 2021
                                  • 45
                                  • algeria
                                  #536
                                  can someone take photos of the 2 chips regions? i think that i knocked a component out and my board doesn't turn on now. thank you
                                  • roli1980
                                    • Nov 2020
                                    • 46
                                    #537
                                    hi can anyone please unlock my 840 g8 - MB 6050A3426501 - MB - A02
                                    thanks in advance
                                    • hoaca388
                                      hoaca388 commented
                                      Editing a comment
                                      You are missing the serial number . And what can we do ?
                                  • roli1980
                                    • Nov 2020
                                    • 46
                                    #538
                                    remove bios password - 5CG2195HD3
                                    • binoyroy
                                      • Sep 2017
                                      • 51
                                      • bangladeah
                                      #539
                                      Check and report.
                                      • roli1980
                                        roli1980 commented
                                        Editing a comment
                                        excellent , thankyou so much
                                    • nesredin
                                      • Feb 2018
                                      • 36
                                      • ethiopia
                                      #540
                                      UNLOCK THIS FILE 840 G8
                                    • Buzzfuzz2k
                                      Bios password removal on a Unowhy dump
                                      by Buzzfuzz2k
                                      Hi Everyone,
                                      I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                      The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                      the Computer is a Unowhy small pc
                                      N° UYM6524702229
                                      After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                      My first attempt was to get the bios dump from windows...
                                      11-13-2023, 07:37 AM
                                    • Ahari
                                      by Ahari
                                      I...
                                      Today, 06:12 AM
                                    • traxformania
                                      TONGFANG "GM7TG7P" Bios Password Problem?
                                      by traxformania
                                      I tried :
                                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                      11-15-2023, 07:32 AM
                                    • Nopslide
                                      by Nopslide
                                      04-01-2024, 04:27 PM
                                    • outsider
                                      Panasonic FZ-G1 MK5 - BIOS password returning
                                      by outsider
                                      Hello
                                      I removed the BIOS password thanks to the help of one of the friends of this forum.
                                      https://www.badcaps.net/forum/troubl...61#post3637661
                                      The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                      06-17-2025, 12:51 AM
