Dell Latitude 3510 with a admin password
    Originally posted by rex98 View Post
    your bios is obviously corrupt that's why the tool doesn't work. read again ang verify in your programmer.
    I've checked the file, read it multiple times and verified it multiple times. It still does not work with the program. Try it yourself.
      Compare your backup with some of the other 8MB backups in the thread, look at the code it`s weird in places,it is corrupt. Are you using a clip and what programmer and software version are you using.
        I used a clip and an push clip for different files. I am using an T48 with XGPro.
          re-upload incase the upload corrupted it.
            If you have another programmer,such as a CH341A make another backup with it.
              Still corrupted do not use clip remove the chip and use adapter
                Thanks, I have used an CH341 + Spring Clip and it's worked.
                  I have Dell Latitude 3510 with locked 8FC8 bios (admin password) and restricted OS (cannot create bios dump as cannot download anything or connect flash drives). Anyway to get bios unlocked?
                  Service tag: BC9VP93
                  Motherboard 0PD7RH Version A04
                  Bios version: 1.6
                  Thanks for any help and guidance.
                    Bios version: 1.6
                    you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                      Thanks! I have ordered the programmer and will update once I receive it and get it to work. Thanks again!
                        Hello All please i have Dell latitude 3510 was locked bios (Admin)
                        Model Name : Dell latitude 3510
                        Service Tag : DL8M4B3
                        When enter to bios show window Admin Unlock
                        And thank You
                        And thank You
                        this model has 2 bios chipsets, read also 64Mb chipset.
                          OK Now
                          File
                            OK Now
                            File
                            write only 64Mbit
                              thank You was Work problem was no Service tag How Can added service tag
                                Bios version: 1.6
                                Here are the bios dumps. There are two chips. Not sure which one is needed. Thanks in advance!
                                  hi, try and feedback
                                    Working perfectly! Thanks a lot!
                                      Please help rebuild bios
                                      dell latitude 3510 ST:627N0B3
                                      Thanks for the help.
                                        You have posted your bios request already in another thread. https://www.badcaps.net/forum/troubl...e7#post3566047 Don`t start another request, read the rules and the PM i sent you.
