GP152 LA-J951P Rev: 1.0 bios request
  • peste
    • Dec 2016
    • 13891
    • ROMANIA
    merged post..
    • Yacine007
      • May 2024
      • 92
      • Maroc
      Originally posted by hoaca388
      Do you know that in the old bios file (original bios) there is the device's DMI and Windows key ? Don't request without the original bios included.
      Im sorry my friend I'm new to this, I didn't know that.
      Original bios Attached
      serial number : CNDO245HXC
      Mother board ID : GPI52 LA-J951P Rev:1.0
      Thank you in advance
        SMDFlea commented
        Editing a comment
        Posts moved to LA-J951P thread.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12432
      HP 250 G7 Notebook PC (15S43ES)
      Serial : CND0245HXC ( Zero )
      Since your BID cannot be determined, you must try all three of these files.
        • 22236
        Its none of those. The 15S43ES has an Ice Lake CPU
        084A6 SPT/KBP-LP ME 11 firmware
        084A8 BSW/CHT TXE 2 firmware
        084AA GLK (Gemini Lake) TXE 4 firmware
        • Yacine007
          • May 2024
          • 92
          • Maroc
          Sorry again bro for the mistake SN is CND0245HXC
          Thank you for your attention and efforts I am very gratefull 🙏
          • Yacine007
            • May 2024
            • 92
            • Maroc
            #26
            I am very grateful if you help us. Thank you in advance
            • hoaca388
              Badcaps
              • Jan 2022
              • 12432
              #27
              Oh, I'm not familiar with this board. Will research later. Thanks !
                SMDFlea commented
                Editing a comment
                It wasn`t 08532 either
            • Yacine007
              • May 2024
              • 92
              • Maroc
              #28
              Ok my friend I appreciate it. Thank you
                • 22236
                Try this one. Its a 16MB virgin bios with your DMI. Can you confirm the bios chip is 16MB or 8MB.If its 8MB its the wrong one.If its 16MB i can only guess that your programmer has detected the chip as only 8MB, or you chose the wrong one
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12432
                  #30
                  I actually extracted three 16MB files and three 8MB files.
                  • volinakis
                    • Jan 2021
                    • 2875
                    • N/A
                    #31
                    you also have to upload 2nd bios chipset backup. BTW, your BID is 086C1
                      • 22236
                      Check them all with MEAnalyzer. Look at the backup again https://www.badcaps.net/filedata/fetch?id=3307911 ,the code ends abruptly.An ice lake bios usually has FF`s at the end afaik. To me that can mean one of three things, that the bios chip is the wrong one,the bios is split across two chips (ice lake can be split across 2 chips but not this one) or the backup wasn`t made properly.
                        • 22236
                        086C1 is only a single bios chip. That leaves a bad backup or wrong chip.
                        Click image for larger version  Name:	Capture2.jpg Views:	0 Size:	52.5 KB ID:	3308313
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12432
                          #34
                          That's right.
                          • volinakis
                            • Jan 2021
                            • 2875
                            • N/A
                            #35
                            he uploaded a 8,4Mb bios image, so I supposed there are 2 chipsets.
                            • Yacine007
                              • May 2024
                              • 92
                              • Maroc
                              #36
                              Thanks to all
                              I am Beginner My knowledge is superficial in this area. I have a small CH341A programmer and plugged it into the bios chip, read it, saved it and transferred it to you.
                              Yeah I inquired with a friend, there are two chipsets, I don't know how to extract from the second chip. I'm going to come back to the station when I manage to extract the second bin.
                              thank you so much
                              • Yacine007
                                • May 2024
                                • 92
                                • Maroc
                                #37
                                I extracted the 8mb file from this main bios chip.
                                Where is the second chip ? Can i extract the file with ch341a programmer ?
                                Mother board image attached
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12432
                                  #38
                                  You don't need to look for the second chip, your chip shows signs of being removed.
                                  • volinakis
                                    • Jan 2021
                                    • 2875
                                    • N/A
                                    #39
                                    what code is written to bios chipset? Image is not clear.
                                    • Yacine007
                                      • May 2024
                                      • 92
                                      • Maroc
                                      #40
                                      XMC
                                      QH128AHIG
                                      PP990200 40
                                      2008C
                                      • cr4zychriss
                                        by cr4zychriss
                                        • Rebrand: PC Specialist
                                        11-14-2025, 04:04 PM
                                      • istvanszasz99
                                        Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                        by istvanszasz99
                                        Product Name: Razer Blade 15 (2022)
                                        Product ID: RZ09-0421
                                        Motherboard: CH580
                                        BIOS Versions I work with: 2.02 & 2.06
                                        Bios File Size: 32,768 KB
                                        Dear Forum Readers!
                                        I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                        I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                        The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                        !!! MY RAZER BLADE...
                                        11-24-2025, 05:52 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
