Lenovo e460 bios problem
  • bilen
    • Aug 2014
    • 632
    • istanbul
    motherboard code : NM-A551
    device turns on and works but
    Invalid RFID configuration information area;
    Invalid RFID serialization information area;
    Machine type and serial number are invalid
    Machine UUID invalid.
    gives an error message. how can i fix this?
    NOTE: I wrote other bios in the forum
    .same result
  • peste
    • Dec 2016
    • 12546
    • ROMANIA
    Re: Lenovo e460 bios problem
    .same result
    DMI information is missing from the bios
    • bilen
      • Aug 2014
      • 632
      • istanbul
      what should I do ?
      • bilen
        • Aug 2014
        • 632
        • istanbul
        Anyone know the solution for this?
          • 20609
          Do you have the original bios backup.
          • bilen
            • Aug 2014
            • 632
            • istanbul
            unfortunately. this is how it arrived
              • 20609
              You will have to add the DMI info . Try this - https://github.com/ASparkOfFire/lenovo-u1-tool .If it doesn`t work look for LVAR64 (lenovo variable tool) or the lenovo hardware maintenance diskette
              • bilen
                • Aug 2014
                • 632
                • istanbul
                0189 error persists:
                It was fixed after the procedure you said :
                ''Invalid RFID serialization information area;
                Machine type and serial number are invalid''
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • grimacelord
                  Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                  by grimacelord
                  Hello there.
                  I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                  History:
                  1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                  I searched for this error online and discovered...
                  03-15-2023, 03:29 PM
                • BootNewbie
                  Lenovo v15 bios corruption! help needed!
                  by BootNewbie
                  3 days prior my Lenovo laptop notified of a bios update, at first I tried to decline it but when i put it on charging lenovo vantage started installing it automatically. After bios was updated i was asked for ftpm reset, first I chose no but same pop up showed up so i had to choose yes. After this concluded i successfully booted, but i had linux dual booted with windows, and it was nowhere to be seen after bios update, i tried secure boot off then successfully entered linux. after shutting down my laptop i encountered this issue:
                  power is supplied
                  screen remains blank (it gets...
                  Today, 11:37 AM
                • mximiliandz
                  help bios lenovo ideapad s145-14iil type 81w6
                  by mximiliandz
                  Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                  06-20-2025, 06:50 AM
                • 1g0r
                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                  by 1g0r
                  First, the data in brief:
                  Manufacturer: Lenovo
                  Model: ThinkPad L15 G3 21C3-0016GE
                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                  IC Bios 1: MX77L25650F
                  IC Bios 2​: MX25L25673G
                  EC Chip: NPCX997KAABX
                  So far I've been a silent reader, but now I need your help
                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                  01-18-2025, 02:39 AM
