asus rog GL503VM
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    asus rog GL503VM
    I'm searching bios for asus rog
    gl503vm DA0BKLMBAD0 REV D
    thanks
  • lapfix
    • Mar 2020
    • 2741
    • my workshop
    Re: asus rog GL503VM
    post your old dump
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      Originally posted by lapfix
      post your old dump
      The motherboard arrived with the bios changed by other technician,
      Before understanding the problem I have to reprogram the ec and use a bios that is known to work.
      If I can't find it, I have to rebuild it
      • vaults
        • Sep 2021
        • 5
        • philippines
        need this bios also, thanks in advance
        • lapfix
          • Mar 2020
          • 2741
          • my workshop
          Gl503!
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            This is for GL503VM
            • Doniciputat
              • Aug 2022
              • 110
              • Indonesia
              Originally posted by jasko_jacker
              This is for GL503VM
              thanks
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • lrouw84
                Asus vivobook s510ua bios changed to x510un
                by lrouw84
                Hi there,
                I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                01-28-2023, 01:31 PM
