need bios dump dell latitude 5420 (cpu 11th)
  • Mazorca
    • Jan 2017
    • 463
    Re: need bios dump dell latitude 5420 (cpu 11th)
    try
    • hoaca388
      Badcaps
      • Jan 2022
      • 12441
      #242
      Originally posted by amine23
      its not powerin at all
      Try clearn ME that file.
      • kazu-2424
        • Aug 2022
        • México
        #243
        Anyone service tag H3QS3J3-8FC8 currently locked and need unlock admin pass?
        • Mazorca
          • Jan 2017
          • 463
          Post your backup BIN file and be sure to do three readings, all identical, start from scratch, use winhex editor to verify. Verify too after re-flashing by doing another reading and comparing to unlocked BIN. I now it seems tedious, but takes about 5 or more minutes and might save you hours of headaches. Also helps to practice if you are going to do this for a living.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            #245
            The device has a very long warranty, please contact DELL support.
            • amine23
              • Apr 2017
              • 89
              • Algeria
              #246
              Hello hoaca338 it dosnt work clean me my backup need repair
              • amine23
                • Apr 2017
                • 89
                • Algeria
                #247
                thank you for your help bro
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12441
                  #248
                  If with the original file (the locked file) the device does not work, then there is a very high chance that you have damaged some component on your motherboard yourself.
                  • amine23
                    • Apr 2017
                    • 89
                    • Algeria
                    #249
                    every thing is good i changes the bios winbond 25q256 now is turn on but the laptop show only diagnostic colors
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12441
                      #250
                      Try testing the output through the HDMI port.
                      • amine23
                        • Apr 2017
                        • 89
                        • Algeria
                        #251
                        there is no external display and there is 6 codes white and 3 oranges it mean recovery bios is corrupte
                        • amine23
                          • Apr 2017
                          • 89
                          • Algeria
                          #252
                          hi bro aldopc this is my original dump in page 13
                          • amine23
                            • Apr 2017
                            • 89
                            • Algeria
                            #253
                            Hello bro
                            i have found the problem its an resistor removed by hot air i need to know the value of resistor
                            • saman mawlod
                              • Apr 2022
                              • 55
                              • iraq
                              #254
                              Originally posted by aldopc
                              ready test
                              can u remove pass
                              • amine23
                                • Apr 2017
                                • 89
                                • Algeria
                                #255
                                trY
                                • aldopc
                                  • Jul 2017
                                  • 484
                                  • Chilito
                                  #256
                                  Hello bro
                                  Hi Bro did you find the value of the resistor, I have an operating board to measure.
                                  • amine23
                                    • Apr 2017
                                    • 89
                                    • Algeria
                                    #257
                                    not yet bro
                                    • Manjunathrawoor
                                      MBR
                                      • Mar 2021
                                      • 42
                                      • India
                                      #258
                                      What do you required exactly
                                      • amine23
                                        • Apr 2017
                                        • 89
                                        • Algeria
                                        #259
                                        after unlock my bios the laptop show diagnostic colors and 6 white codes and 3 orange
                                        • nikola07
                                          • Sep 2018
                                          • 36
                                          • Ukraina
                                          #260
                                          good afternoon unlock please my bios is very necessary
                                          • mirjana
                                            EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                            by mirjana
                                            I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                            The embedded controller is MEC5107-LJ (UE1).
                                            The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                            I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                            If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                            Thank you in advance!...
                                            07-16-2025, 12:55 AM
                                            DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                            09-06-2024, 03:21 PM
                                            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                            09-06-2024, 09:23 AM
                                            09-06-2024, 08:47 AM
