need bios dump dell latitude 5420 (cpu 11th)
  • roystan05
    • Sep 2024
    • 16
    #1001
    Originally posted by Sparo
    Okay Those are working files two with the same SKU as yours and one is different (which I made on purpose for your case)
    Just after writing the file make sure to verify the write and check the soldering too
    Still having same issue with the other files? I am not sure what im doing wrong. The chip has 3.3V voltage but nothing happens when power button is pressed. Not sure if the chip is write protected. i have used Neoprogrammer and it writes the file with verfication successfully but if i use AS programmer i get verification error when it is erased. Is there a way to disable write protection.
    • Sparo
      Sparo commented
      Editing a comment
      I've never worked with CH341a (Started with the old MiniPro) so I'm not sure
      But I think the BIOS chip needs to be replaced, it appears to be faulty
  • LBTT1121
    • Nov 2024
    • 2159
    • Việt Nam
    #1002
    Try replaced BIOS chip
    • roystan05
      • Sep 2024
      • 16
      #1003
      I think I need to mod the programmer for 3V. The chip may be the culprit. I was able to copy the dump using pogo clip without desoldering. Edited the bios and wrote back and I was not able to power on the laptop. Next I desoldered it and reverted back to original dump, same amber light issue. When I read the chip it successfully reads the contents but has issue while writing it. Just want to know can I replace W25R256JV with any other chip from winbond 256 32MB chip or it should be exact chip. I have I have few W25Q256 chips from donor boards.
      Thank you for your help.
      • LBTT1121
        • Nov 2024
        • 2159
        • Việt Nam
        #1004
        Replace W25R256JV
        • Sparo
          Quicksilver
          • Jan 2022
          • 4554
          • M\A
          • Anime, Edge Computing, Football, Snooker
          #1005
          Affirmative. You can replace it with any other 256 32MB chip (not only Winbond) as long as it operates at 3V and not 1.8V
          Winbond example: the JV or FV family are compatible but not the JW family (because W25Q256JWXXX chips run at 1.8V)
          Enjoying our forum? Subscribe to unlock extra perks!
          >> Upgrade here <<
          • freenlnl
            • May 2014
            • 36
            • The netherlands
            #1006
            Hi everyone. I have a Dell Latitude 5420. My problem is that it came with Absolute locked as enabled, could someone please remove it for me?
            Details:
            - Board: GDF40 LA-K491P Rev 3.0 (A02).
            - BIOS chip: W25Q256FV.
            - Service Tag: GKf26j3.
            Thank you very much!
            • Sparo
              Quicksilver
              • Jan 2022
              • 4554
              • M\A
              #1007
              Details:
              Hi Try this file
              >> Upgrade here <<
              • freenlnl
                • May 2014
                • 36
                • The netherlands
                #1008
                Hi Try this file
                Thank you , i tried but Np power!
                • Sparo
                  Quicksilver
                  • Jan 2022
                  • 4554
                  • M\A
                  #1009
                  Try again and verify the write and soldering too
                  because normally it should work
                  >> Upgrade here <<
                  • LBTT1121
                    • Nov 2024
                    • 2159
                    • Việt Nam
                    #1010
                    @freenini try
                    • freenlnl
                      • May 2014
                      • 36
                      • The netherlands
                      #1011
                      @freenini try
                      Sorry for late reply - laptop power on but no image.
                      • freenlnl
                        • May 2014
                        • 36
                        • The netherlands
                        #1012
                        I tried again it works but Absolute still ON. thx
                        • shiyab
                          • Sep 2023
                          • 3534
                          • india
                          #1013
                          hi try i just restore the security settings
                          • eliteittraders
                            • Apr 2026
                            • Pakistan
                            #1014
                            Hi plz dell latitude 5310 ok bin 25q128 25q64 ok bin file clear me
                            • eliteittraders
                              • Apr 2026
                              • Pakistan
                              #1015
                              Hi plz clean me file
                              • LBTT1121
                                • Nov 2024
                                • 2159
                                • Việt Nam
                                #1016
                                and what is your problem??
                                post motherboard model, Service Tag , etc.
                                post the contents of the bios chip even if it is corrupted
                                • pronto
                                  • Mar 2019
                                  • 235
                                  • morocco
                                  #1017
                                  hi dell latitude 5420 all its good mybe problem bios
                                  Service Tag/7ZBQ5J3
                                  • LBTT1121
                                    • Nov 2024
                                    • 2159
                                    • Việt Nam
                                    #1018
                                    Service Tag/7ZBQ5J3
                                    try
                                    • hollo13
                                      • Mar 2017
                                      • 27
                                      • Hungary
                                      #1019
                                      Hi everyone. I have a Dell Latitude 5420. My problem is that iwifi switch, not switchable in bios settings, colored grey. Not active.
                                      Plese hlep me.
                                      Board: GDF40 LA-K491P Rev 2.0 (A01)
                                      Service tag: CXKH7D3
                                      Thank You
                                      • shiyab
                                        • Sep 2023
                                        • 3534
                                        • india
                                        #1020
                                        Plese hlep me.
                                        Thank You
                                        hi try
                                        • mirjana
                                          EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                          by mirjana
                                          I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                          The embedded controller is MEC5107-LJ (UE1).
                                          The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                          I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                          If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                          Thank you in advance!...
                                          07-16-2025, 12:55 AM
                                        • Boardview and Schematic Bot
                                          DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                          09-06-2024, 03:21 PM
                                          DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                          09-06-2024, 09:23 AM
                                          09-06-2024, 08:47 AM
