need bios dump dell latitude 5420 (cpu 11th)
  • puls
    • Oct 2017
    • MEXICO
    #301
    Re: need bios dump dell latitude 5420 (cpu 11th)
    Originally posted by onizzbox
    @i4mm3
    Unlocked!
    screen blink color and restar only. Any fix plese
    • tarek5313
      • Mar 2015
      • 30
      #302
      same for me 3 color screen
      • hoaca388
        Badcaps
        • Jan 2022
        • 11733
        #303
        This file
        • hoaca388
          Badcaps
          • Jan 2022
          • 11733
          #304
          Post your locked bios file here.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11733
            #305
            Try this file and let me know.
            This file not work.
            • tarek5313
              • Mar 2015
              • 30
              #306
              Originally posted by hoaca388
              This file
              yes this one
              please have a look
              • hoaca388
                Badcaps
                • Jan 2022
                • 11733
                #307
                yes this one
                please have a look
                File at #313 was fixed.
                • tarek5313
                  • Mar 2015
                  • 30
                  #308
                  this one worked, it let me enter new svtag, but after i disable manfacturing mode by Alt-F it servive 2 reboot then it die for good
                  after looking into many dumps here on this thread i noticed your modification involve 3 different offeset 2byte on each
                  hardware1 modification involve 2 offset 2 byte again
                  Vesko356 involve 4 offset again 2 byte only
                  not sure which one is the good method here, but diffenetly something is not perfect here
                  from what i understand and i might be wrong here, excuse me
                  you guys spoiling EC Region to force manfucturer mode and somehow it resurect by Backup Embedded Controller, hmm intresting
                  i am not complaining or criticising anyone here, just trying to understand how things works is always make me smile
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11733
                    #309
                    It's very random, sometimes 1 offset, sometimes 2, sometimes 3 or 4 offsets.
                    • tarek5313
                      • Mar 2015
                      • 30
                      #310
                      ok, so what you can advice about my case?
                      machine gose dead once i exit manfacturing mode by Alt-F
                      then i have to reflash the file again to bring back in working condition but i have to keep it in manfacturing mode or it gose dead again
                      original dump dosen't work at all now
                      please help
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11733
                        #311
                        please help
                        Try again
                        • Ali5914
                          • Dec 2020
                          • 48
                          • India
                          #312
                          Originally posted by osman68i
                          GDF40 LA-K491P 5420 with password
                          can someone unlock this bios
                          Hi friend, i have build a fresh bios with MPM Unlock....
                          Please check and update... and if this is working then please share motherboard part no image and CPU SR no from CPU as well.
                          • tarek5313
                            • Mar 2015
                            • 30
                            #313
                            Try again
                            Yes now everything is ok
                            thank you
                            • volinakis
                              • Jan 2021
                              • 2733
                              • N/A
                              #314
                              please help
                              remove battery for 2-3mins. and put it again. If you powered on without battery after you modified bios this was the cause. Happened to me also, I rewrite again bios with modified bin thinking it wasn't write right and 2nd time I did connect battery before start and worked without problem when i exit from factory mode.
                              • darckreign1984
                                • 260
                                #315
                                dell latitude 5420
                                bios chip its winbond 25r256jven
                                laptop did not start after bios update - now only keyboard light up.
                                i have tl866II can this read the dump? and repair here with your help?
                                any advice?
                                thanks
                                • layad
                                  • Nov 2011
                                  • 246
                                  #316
                                  if some one unlock admin password please
                                  • hardware1
                                    • Sep 2021
                                    • 2930
                                    • N/A
                                    #317
                                    Here's your Unlocked file, hope it works fine.
                                    all donations are welcome,
                                    • layad
                                      • Nov 2011
                                      • 246
                                      #318
                                      worked like charm thankkkks , i have an other 2 laptops which have the same modle, can i use the same file? and input the service tag manualy?
                                      • hardware1
                                        • Sep 2021
                                        • 2930
                                        • N/A
                                        #319
                                        It's better to use the original bios for each device to avoid problems and warning messages, because the bios file contains service tag, windows key, MAC address, and more..
                                        Perhaps if you clean the ME region the file can work for other devices.
                                        • layad
                                          • Nov 2011
                                          • 246
                                          #320
                                          thanks would you help me with second one pls?
                                          • mirjana
                                            EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                            by mirjana
                                            I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                            The embedded controller is MEC5107-LJ (UE1).
                                            The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                            I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                            If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                            Thank you in advance!...
                                            07-16-2025, 12:55 AM
                                            DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                            09-06-2024, 03:21 PM
                                            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                            09-06-2024, 09:23 AM
                                            09-06-2024, 08:47 AM
