RCUnlocker
Do you mean there are two bios chips on my PC? Coz I only see one chip beside the label 'bios' on the motherboard and two other 8 terminal chips on separate locations and they're a bit smaller in size, and I can't see their markings unless I use a magnifying glass. One is closer to the main chip that I backed up earlier and the other is closer to the CMOS battery.
Do you mean there are two bios chips on my PC? Coz I only see one chip beside the label 'bios' on the motherboard and two other 8 terminal chips on separate locations and they're a bit smaller in size, and I can't see their markings unless I use a magnifying glass. One is closer to the main chip that I backed up earlier and the other is closer to the CMOS battery.Comment
Hi and Welcome to the Foum! You need to Post the Serial Number with every single request, Take some time to read the Forum rules
Here they are > RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - Badcaps
1- To fix the error you're seeing, you need to install the Microsoft Visual C++ Redistributable packages
> https://aka.ms/vs/17/release/vc_redist.x64.exe and https://aka.ms/vs/17/release/vc_redist.x86.exe
2- Use the RCUnlocker on the EC chip located on the backside of the motherboard, near the battery connector
3- If you still can't somehoww get it working, then post the Serial Number and the EC chip backup I already pointed outComment
It turns out I was just missing a few things on my PC but now it has worked thanks to your guides, this platform has saved me!🙏
Hello everyone, I need help removing the BIOS password for an HP EliteBook 850 G8. Here are the hardware details: - Motherboard Model: 6050A3216701-MB-A01 - Chip Model: W25Q256JV (32MB, read as U367) - Serial Number (S/N):#8CG3311W2V I have attached the original 32MB dump read with my RT809H programmer. RCUnlocker did not accept it due to the 16MB file size limitation. Could someone please patch/unlock this file for me? Thank you in advance for your time and help!Attached FilesPremium supporters get full download access and other benefits.
Here they are > RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - BadcapsComment
Contact the Admin - https://www.badcaps.net/contact-usOriginally posted by WampaStompa!!!Am I required to pay before I can download RCUnlocker? I just need RCUnlocker and the link isnt working.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Yes I tried with different pc but now I realise an issue when I make backup file there a additional 1 byte file comes with 16,385 and when I download file comes with 16,384(which rc unlocker works well with this) I use xgecu programmer I tried to update to latest version but still comes with I additional 1 byteComment
Read this, it explains the solution - https://www.badcaps.net/forum/troubl...ckup-file-sizeYes I tried with different pc but now I realise an issue when I make backup file there a additional 1 byte file comes with 16,385 and when I download file comes with 16,384(which rc unlocker works well with this) I use xgecu programmer I tried to update to latest version but still comes with I additional 1 byteComment
Hi, could you please help me?
HP Elitebook 830 G6, S/N: 5CG94692MK, i read the 32 MB Bios file and get the message "Wrong Chip". Could you please help? Thanks!Attached FilesPremium supporters get full download access and other benefits.
Hi, The size of the compressed backup file is wrong (682.2KB)
Use this small tool and follow the instructions > https://www.badcaps.net/forum/troubl...55#post3863055Comment
Hello everyone, I have HP X360 Elitebook 830 G8. Have bios password problem, please help.
Tried to edit with hex editor and got 7 long caps lock flashes.
S/N: 5CG32124Q8
MB Model: OPEL-6050A3219701(A1)
EC chip dump uploaded below.
tryAttached FilesPremium supporters get full download access and other benefits.
Also did main bios dump if it can help.Attached FilesPremium supporters get full download access and other benefits.
Hi, When compressing files, choose an actual compression method...
> Pick Normal/Good/Best instead of "Store" which means no compressionAttached FilesPremium supporters get full download access and other benefits.
by SMDFleaJust a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
the infamous **"Endpoint Security" error message.
Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
The offsets and file sizes are part of the naming convention i`ve used for the extracted
files.
hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
filling everything after...-
Channel: BIOS Requests ONLY!
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 06:40 AM
This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-07-2024, 05:50 AM
- Loading...
