RCUnlocker
Every donation made will go towards server fees and maintenance costs. -
Every donation made will go towards server fees and maintenance costs.Comment
In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
Good day to you! Unfortunately, both your programs could not remove the password, after flashing the prepared file, the password is still present. Could you help with this laptop? Thank you in advance!
Hp probook 650 g4Attached FilesComment
Hp probook 650 g4
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
I don't want to litter the topic, but unfortunately I can't edit previous messages, so I'm writing a new one. After reading many forum threads, I realized that in this particular model the password is in a 32 MB flash drive. I'll add the original 32 MB dump file to the message.
Hp Probook 650 G4
Serial number : 5CG91238YF Motherboard: Chromia 6050a2930001
Hp Probook 650 G4
Serial number : 5CG91238YF Motherboard: Chromia 6050a2930001Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
for which laptop??
post S/N, full name and model, motherboard model, product number,etc.
post the original contents of the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hello.
I tried two tools for removing the BIOS password, but nothing happened
If you can help please with this problem
Thank you!
Hp Elitebook 835 G10
Serial number : 5CG35037L8
ProdID 709Z0AVAttached FilesComment
CTNumber_6MBNK0FTZIQDE7
Serial_5CG35037L8
Product_709Z0AV
Fearture byte_476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUcAeMfPgSguhKjhk8mEmVn7nWngpDpnpqprqMqkqz.mA
Build Id_23WWLOBZ601#SABD#DABD
Goodluck !Attached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hi
I'm trying to get the password off HP ZbooK 14u G6. Unfortunately, even though I do everything correctly in RCunlocker I get the message "Wrong chip.
Try reading and unlocking 16mb chip" Can someone help? I'd be grateful.
HP Zbook 14u
ProdID 6TP69EA#ABY
SN 5CG9448MNG
Thank youAttached FilesComment
Hi
HP Zbook 14u
ProdID 6TP69EA#ABY
SN 5CG9448MNG
Thank youComment
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by hazem3636hi everyone
i need dump file for dell server r220
i have download Flash BIOS executable file but i dont know how to conver it to Bin file
i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
if anyone has this method please need his supporting .
all the best
EXE file is attched and Original Bin file from the Bios Chip is attached also
and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...-
by abudoHi,
I hope you are all doing well. I need help getting hardware reference for HP PROBOOK 450 G5
Board ID is DA0X8CMB6E_REV_E
BR,
Abe-
07-21-2022, 07:10 PM -
First check this site to see if your HP is supported for the great tool Mazzif has made.
http://mazzifsoftware.blogspot.com/p...os-unlock.html
If your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
When you have your dump, just drag and drop your file on my HPUnlocker tool...-
Channel: BIOS Requests ONLY!
- Loading...
