Hey I am trying to unlock an HP Elitebook 830 G7. I am very new to this, so are there step by step instructions on what to do in order to use this RCUnlocker?
RCUnlocker
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Every donation made will go towards server fees and maintenance costs.Comment
hey
been using the tool for some years, but on my new computer i only get pyhton script error, really no matter what i do ..
attached the dump if someone could patch it for me? Probook 450 G6,
regardsAttached FilesComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
Unlocking
HP - ProBook, EliteBook, ZBook (including 32MB models)
Chromebooks from all various manufacturers
Apple - everything older than T2
More to come...
Information display (helps to verify file integrity)
HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
Custom logo removal
Usage: Drag and drop .bin file to .exe file.
In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
You may ask for feature requests, I'll see what I can do.Comment
Hi I am running into a problem with a HP 840 G5 that won't boot after using the tool. I have used the tool multiple times successfully before but for some reason this time it isn't. Heres the steps I did.
- I desoldered the 16MB chip on the back of the motherboard and programmed it with RCUnlocker then soldered it back on
- I attempted to boot the device and the speakers beeped at me and then I remembered I forgot to put the RAM back
-I put the ram back in and then booted the laptop succesfully I tried to get to the bios to reset security settings but wasn't able to.
- The bios said "completing last step of the bios update do not power off" after that finished the embedded controller security error showed up
- The laptop then powered off and now it won't boot again. The caps lock blinks 5 times and the laptop won't power on anymore.
I tried removing the 16MB chip and programming it again and soldering it back on again but now the caps lock is just a solid light, no blinking and the laptop does not turn on. I tried unplugging the cmos and draining the power but it did not do anything.
Did the main bios chip get corrupt? I don't have a backup of the 32MB chip only the 16MB.Last edited by hypermk735; 03-25-2024, 03:55 PM.Comment
Yes I already tried a full power drain to try to recover the bios but no luck. Would you happen to know how I can get a clean bios for 840 G5 with MPM unlocked?Comment
Hi guys I'm struggling with unlocking this particular HP EliteBook 645 g9, this tool keeps failing to unlock
I split the main bios the lower part is the one containing the PW it's 16MB so now I can use your script on it
Well the file I get in the output is the same as the original, I compare both they're identical
any suggestion how to clean it SN#5CD3291R3D MB: DAX9SFMB8A1 REV:AAttached FilesComment
Or use this HP BCU TOOL ( BIOS Configuration Utility) to fill the DMI infoAttached FilesComment
At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in to bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover.
what tool did you use? RCUnocker? IDK why it didn't work for me I'm confusedComment
you can disable permanently the absolute lock in BCU tool.
here's your DMI info. use bcu:
Serial Number: 5CD3291R3D
Product Number: 6J5H9AV
CT Number: PREBK068JIB04V
Description: HP EliteBook 645 14 inch G9
build_id: 22WWTPCZ601#SABF#DABF
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPguhKhkjhk8mEn7nWpDpFpnpqprqjqz.Hg
MAC Address: BC-0F-F3-8A-2E-7FAttached FilesComment
Hi does anyone know the correct way to remove a bios password off of a HP with a 32MB ec chip? I have 20 ProBook 450 G8 laptops that need to be unlocked for a client. I have had success in the past using RCunlocker from rhetoricalcheese on 840 G6 and 840 G5 but the tool only works on 16MB ec chips not 32MB.
I could ask someone to unlock a bin file for me but I need to do this over 20 times so I need to learn the method.
I have a working unlocked MAIN + EC bin from another laptop if that helps
I tried to flash those working bins to a unlocked laptop and used some tool to change the dmi info to match the serial but the laptop doesn't boot so I assume I can't do it that way. Please help!Comment
by SMDFleaJust a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
the infamous **"Endpoint Security" error message.
Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
The offsets and file sizes are part of the naming convention i`ve used for the extracted
files.
hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
filling everything after...-
Channel: BIOS Requests ONLY!
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 06:40 AM
This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-07-2024, 05:50 AM
- Loading...
