Lenovo ideapad 5-14IIL05 BIOS bin
  • lightfinger
    • Jun 2020
    • 12
    anyone got a bios bin for the ideapad 5-14IIL05? The one I got is making the laptop blink the powerlight and CPU go warm. BIOS seems to not do POST.
    • 21002
    Re: Lenovo ideapad 5-14IIL05 BIOS bin
    Post your backup
    • lightfinger
      • Jun 2020
      • 12
      my backup is corrupt as the bios chip itself was bad.
        • 21002
        Post the corrupt backup ,there might be some DMI info. What programmer and software version are you using.
        • lightfinger
          • Jun 2020
          • 12
          I'm using the below.
          tried on both CH314A and RT809F
          tried the AIR-14IIL 2020 FLMS0 LA-J551P Rev 1.0 - all power lights blink continuously including function lock with CPU GPU and SSD heating up.
          Got a 8MB extract and a 16 MB extract both using CH314A and is attached
          Modified the bios section for the FLMS0 LA-J551P Rev 1.0 BIOS with same result.
          To modify used HEX Workshop v6.7
          Programmer version 1.38 for CH314A
          Programmer version 20210410 for RT809F
          • lightfinger
            • Jun 2020
            • 12
            with attachments
              • 21002
              with attachments
              Bios + EC .Your version is DSCN34WW (DOSFLMS0) . ideapad 5-14IIL05 Laptop - Type 81YH
              The other one is for some of the other models listed (Use hex editor text search: BVDT)
              IdeaPad 5 14IIL05,14IIL05 U,14IIL05 D, XiaoXin-14IIL 2020, XiaoXinAir-14IIL 2020, Lenovo Ducati 5
              • lightfinger
                • Jun 2020
                • 12
                Thank you very much. You saved my day.
                • O.Szilard
                  • May 2019
                  • 161
                  • hungary
                  Re: Flex 5-15IIL05 / LC55-15C
                  Hello, please help Lenovo Flex 5 14IIL05 81X1
                  LC55-15C 19792-1 448.OK106.0011 SEARCH BIOS dump. The machine turns on, cpu cooler rotates high, the screen is black
                    • 21002
                    Try this one and leave feedback .
                    Flex 5-14IIL05 Laptop (ideapad) - Type 81X1
                    ECCN36WW
                    • O.Szilard
                      • May 2019
                      • 161
                      • hungary
                      Thanks, but same problem. CPU fan with high speed and black screen
                      • bushmann
                        • Feb 2014
                        • 147
                        • Slovakia
                        Please can you help me.
                        I read this model from BIOS, but I don`t know is it correct " Flex 5-14iil05 ".
                        After BIOS update not start.
                        I need EC file for motherboard model
                        LC55-15C
                        19792-SB
                        448.0K106.00SB
                        this model have Nuvoton EC ic and not have Nvidia GPU.
                        thanks for your help.
                        • peste
                          • 12868
                          • ROMANIA
                          LC55-15C
                          19792-SB
                          448.0K106.00SB
                          posts the original bios of the laptop, the full name and model and TYPE ....
                          • bushmann
                            • Feb 2014
                            • 147
                            • Slovakia
                            So I have a Flex 5-14iil05 model and this model has a Nuvoton EC.
                            I don't know if it's the right model, I read it from the BIOS.
                            The customer updated the BIOS and did not start after the restart.
                            Flash for EC is empty "FF".
                            This model does not have a Nvidia GPU.
                            LC55-15C
                            19792-SB
                            448.OK106.00SB
                            I didn't find any label on the laptop itself, just what I wrote.
                            Thanks.
                              • 21002
                              LC55-15C
                              19792-SB
                              448.OK106.00SB
                              @peste asked you for the machine type, if you don`t know what it is post the serial number,or a picture of the sticker on the base
                              • bushmann
                                • Feb 2014
                                • 147
                                • Slovakia
                                Nothing is written on the base.
                                I don't know the model or the serial number.
                                I already had several models that had nothing on the base.
                                I looked but I didn't find anything. If I had some of these numbers, I wouldn't write here. I only have the label on the motherboard, which I wrote above. I read the model I wrote above from the BIOS chip.
                                I have no further information.
                                • dhibubabu
                                  • Dec 2014
                                  • 50
                                  • UAE
                                  Bios need ideapad flex 5 14iil05 81x1
                                  LC55-15c
                                  19792-3
                                  448.0k105.0031
                                  orginal bios is no display,ATTACHED
                                  • peste
                                    • 12868
                                    • ROMANIA
                                    Re: Bios need ideapad flex 5 14iil05 81x1
                                    LC55-15c
                                    19792-3
                                    448.0k105.0031
                                    try post # 10 ....
                                    https://www.badcaps.net/forum/showth...d+flex+14iil05
                                    • dhibubabu
                                      • Dec 2014
                                      • 50
                                      • UAE
                                      once i program that file
                                      display on and backlight only (blank display)
                                      then i turned off and on again
                                      no display
                                      • peste
                                        • 12868
                                        • ROMANIA
                                        no display
                                        is the bios extracted from the Lenovo site update, either you typed it in error, or the laptop has another problem ...
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          by grimacelord
                                          Hello there.
                                          History:
                                          03-15-2023, 03:29 PM
