Inspiron 5491 2 in 1 bios dump needed.
  • lngcs
    • Jul 2011
    • 69
    Hi, anyone please upload bios dump for dell inspiron 5491, p93g001. machine turn on with keyboard backlight but no diplay. thanks
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Inspiron 5491 2 in 1 bios dump needed.
    Upload your bios backup here.
    Become a Badcaps supporter
    Thanks to all supporters.
    • lngcs
      • Jul 2011
      • 69
      here is my bios dump.thanks
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Try:
        • lngcs
          • Jul 2011
          • 69
          Tried, this bios power then turn off. and nothing.
          • lngcs
            • Jul 2011
            • 69
            I tried reprogrammed second time. power on then off. then on again. cpu did not get warmed and no keyboard backlight like the original bios.
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              It seems your problem is not bios related in this case, more likely you had a hardware issue.
              • DanielDacko
                • Mar 2015
                • 325
                • Macedonia
                Originally posted by Vesko356
                Try:
                Your file is not ME cleared, it's just initialized. Unfortunately, I can't clear it too, this is merely just observation.
                I don't provide help for people using CH341A and a clip.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  It does not need to be cleaned, as it is original/native dump, and ME firmware was already "married" with the hardware. If it had to be cleaned, I would have done it with or without these observations of yours, so it is not bad to both observe, and to learn some basic concepts.
                  Of course, there is a possibility that OP didn't program the chip correctly, especially if he didn't use verification, there is a possibility that it is not soldered correctly on the motherboard, and so on.
                  But the problem is not always in the bios, and most of the times unfortunately it is just a hardware issue.
                  BTW If you want to learn there is an excellent guide, you can find out how to do it -----> https://www.badcaps.net/forum/showthread.php?t=88533
                  • lngcs
                    • Jul 2011
                    • 69
                    Thank you Vesko356 for supplied the bin file. it could be dead cpu. i'm willing to try more bin file to see if it works if anyone else got working dump.thanks
                    • lngcs
                      • Jul 2011
                      • 69
                      Just to clear thing about how i program the bin file. i have both sofi sp8 and RT809f both were used and same results. no cpu warm up and fan spin like the old bios.
                        • 21177
                        Try this one .
                        • lngcs
                          • Jul 2011
                          • 69
                          ok, this one behave exactly the same as the one provided by Vesko356. this time also did voltage check on each of the coil. With the original bios all voltage present. 3.3v,5v,1.02v,1.2v and 0.8... when programmed with bios from SMDFea, i have missing 1.02v(pch),0.8v(cpu) and 1.2v(ram). is that mean wrong bios or cpu can not be initialize?
                          • syed faizan
                            • Aug 2019
                            • 7
                            • india
                            Originally posted by SMDFlea
                            Try this one .
                            HELLO need bios for dell inspiron 5491.im attaching my ola dump
                            • ahmarzo
                              • Mar 2015
                              • 171
                              • india
                              dell 5491 bios problem
                              i have dell laptop service tag no F637ZZ2 with bios issue have got the dispaly with other bios but giving tpm error and laptop doesnt go into sleep mode.plz make me a working bios with backup bios attached.
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                Re: dell 5491 bios problem
                                try
                                • ahmarzo
                                  • Mar 2015
                                  • 171
                                  • india
                                  thanks working fine
                                  • qayyum786
                                    • Aug 2018
                                    • 1933
                                    • INDIA
                                    thanks working fine
                                    good to hear that "mumbaikar"
                                    • psinh99
                                      • Feb 2015
                                      • 53
                                      • viet nam
                                      Could you please tell me the name of the bios chip? My motherboard has lost its bios chip
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11889
                                        Here
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
                                        • James Maxwell
                                          HP DM1-4000er Bios Dump needed
                                          by James Maxwell
                                          I badly need bios dump for HP DM1-4000er,
                                          Model: HP DM1-4000er
                                          Motherboard: DA0NM9MB6D0 REV.D
                                          Product: QJ490EA#ACB
                                          Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                          10-28-2024, 05:38 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
